Anyone Who Has Changed A Fuel Filter Help!!!
Old Mar 7, 2004 | 07:48 AM
BrandonSE's Avatar
My car is sitting in my driveway right now, basically i posted a thread about this a week ago to see what kind of problems i might have, from the responses i got it didnt seem to hard, so i went to go take out the back seat then proceeded to take out the 3 screws holding the plate that says 2y then i unscrewed about 3 screws holding, im guessing the fuel pump, i heard pressure being released, thought that was probably usual, then i went and did the rest. I noticed i couldnt get the pump out without taking off the 3 connectors, so i did the harness one that goes from the plate that says 2y and then i tried one of the other connectors and i think gas came out so i quickly wiped it down and put that connector back on and tried to put everything back together but now the O ring wont fit, and i dont know what to do, I know i would have to replace the O ring, but what do i do? Is it normal to have fuel come out? Pressure released? Help please
thanks
brandon
Old Mar 7, 2004 | 12:56 PM
Y2KSESteve's Avatar
It is totally normal for the pressure to be released and for some fuel to spill out of the fuel pump assembly. The stock O-ring won't work as well as it should since it is somewhat old and has expanded.
Old Mar 7, 2004 | 04:09 PM
WILLSE's Avatar
make sure u get a new O ring. fuel sprayed out like hell when i did mine. make sure that u dont strip the 8 screws that holds the fuel pump assembly down. the fuel filter is rather easy to replace after the assembly is pulled out. also i believe it says in the ESM that the pressure regulator O ringt needs to be replaced along with the pressure regulator clip. i only replaced my O ring on the eye hole. i dremeled my old fuel fiter apart and DAMN that thing was DIRTY. have fun and be very careful.
will
Old Mar 7, 2004 | 04:17 PM
young1976's Avatar
someone did a write up for this not long ago with pics and words. I don't know where it is, look in how tos and the 5th gen threads. I however saved a copy of the whole thread and edited the appearance so when I do this I will have instructions. Thanks to who ever did it. I don't remember who though. If you PM me I will email you the Word Doc that I saved it as.
Old Mar 7, 2004 | 05:53 PM
housecor's Avatar
Not sure if you saw this how-to: http://forums.maxima.org/showthread.php?t=276627
Old Mar 7, 2004 | 06:00 PM
BrandonSE's Avatar
Thanks alot guys, i ended up just taking the new O ring i had and putting it on , i got the fuel pump out, looked at it and just said forget it, i didnt want to mess up anything. Thanks for the link housecor, i found that, after i put it back together. I regret ever even trying this. I still have the new filter, but unless i do this with someone who has experience, forget about it. Thanks alot though guys
brandon
Old Mar 8, 2004 | 08:18 AM
young1976's Avatar
yea that's the one, credit goes to spirilis
Old Mar 8, 2004 | 12:17 PM
studman's Avatar
Note to users who do this:
After you pull the fuse and run the car empty, remove the gas cap to release extra pressure. Doing so will make the removal process a little cleaner.
Also, keep a towel around to soak up the gas that is inside the filter/pump assembly so that you don't spill it on the carpet, etc of the backseat.
Old Mar 8, 2004 | 12:23 PM
Colonel's Avatar
Old Fuddy Duddy
Also make sure to do this only when the gas light kicks on...keeps the spillage to a minimum. Go slow and it wont be a problem in addition to the above advise. I had a small wide basin (portable cooler second shelf thingy) that I move the fuel assembly directly to. Only about 1 or 2 inches tall.
Old Mar 8, 2004 | 03:14 PM
young1976's Avatar
and don't SMOKE or make a spark and plenty of fresh air!
Old Mar 8, 2004 | 08:47 PM
ICULookN's Avatar
real nice site.
The Wizard
24
Oct 1, 2015 08:47 PM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
aminus21
Sep 12, 2015 04:53 PM
sdotcarter
Sep 2, 2015 09:53 PM
