Need a "How-To" on replacing my front rotors
Old Mar 13, 2004 | 02:54 AM
LouE37's Avatar
Does anyone have or know where to get a "How-To" on replacing the front rotors on a 5th Gen?
Old Mar 13, 2004 | 06:32 AM
irish44j's Avatar
retired moderator
It's actually quite easy to do. Just buy a Haynes manual for your car at the local auto store, the instructions are quite clear. Only special thing that is helpful is having a screw of a certain size which you can screw in to "pop" out the rotor if it's a little rusted in there. I didn't have one, so used a rubber mallet to pop it loose (carefully).
Really all you have to do is take off the wheels and then rotate the caliper out of the way. Then the rotor will just pop off with a little effort.
Like I said, get a haynes manual and you'll have no problem. It's a 1/2 hour job to change out the front rotors...
Old Mar 13, 2004 | 03:03 PM
Max2000's Avatar
check the top of the 5th gen forum, in the "how to" section, there is instruction in there....
you DO need a C-Clamp though.
I did it myself.. it's pretty easy....
03VQMAX
Sep 25, 2015 04:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
Samedi
Aug 12, 2015 01:54 AM
RealityCheck
Aug 5, 2015 06:18 AM
