Suspension Squeaking..................Anoying
Old Mar 19, 2004 | 06:47 PM
Ammi's Avatar
350 Detroit Muscle
Buddy of mine and I changed his OEM shocks w/ a set of slightly used OEM shocks. About 50 miles after installation, driverside front suspension started squeaking. Seems like whenever there's a slightest bump on the road, suspension would squeak.
Yesterday, he got a wheel alignment done. Squeaks were reduced greately. I couldn't hear any squeaks in his car. After about 150 miles of driving, squeaking came back.
Any ideas?
Old Mar 19, 2004 | 08:19 PM
MacAlert's Avatar
Why would you switch from OEM to OEM?
Old Mar 19, 2004 | 08:22 PM
Ammi's Avatar
350 Detroit Muscle
worn out shocks. Got the other set for free
Old Mar 19, 2004 | 08:26 PM
MacAlert's Avatar
Ahh, cool. Did you put the spring isolators on and have the springs seated right?
Old Mar 19, 2004 | 08:47 PM
Ammi's Avatar
350 Detroit Muscle
Spring isolators?
If springs weren't seated properly, it would make a popping sound but rather it's a high pitch squeaking.
Old Mar 19, 2004 | 08:48 PM
irish44j's Avatar
retired moderator
everything tightened down to torque specs?
Old Mar 19, 2004 | 08:50 PM
housecor's Avatar
Anyone know the torque specs for the suspension components?
Old Mar 19, 2004 | 08:55 PM
irish44j's Avatar
retired moderator
balljoint to steering knuckle nut 62 to 76 nm
strut to steering knuckle bolts 140-159 nm
strut upper mount nuts 39-54 nm
piston rod nut 59-88 nm
NOTE NEWTON-METERS not FT-LBS!!!
irish44j's Avatar
retired moderator
per my Haynes manual, not the nissan shop manual...
Old Mar 19, 2004 | 09:04 PM
Ammi's Avatar
350 Detroit Muscle
everything is tightened down good. Would bad strut make squeaking noise?
Old Mar 21, 2004 | 12:34 AM
jattmax's Avatar
i had a similar problem on my honda, i know its a diff car but symptoms were same, when i would go over bumps or if the suspension would flex i had squeakin noises... les schwabbie lubricated something, have no clue what cause its been about 7-9 months but i've had no squeaking at all since then... its worth a try... PM me if you need help i can find out what they lubricated...
Old Mar 21, 2004 | 06:18 AM
housecor's Avatar
Awesome, thanks! I didn't even think about checking Haynes since there isn't one released yet for the 5.5 gen.
Old Mar 21, 2004 | 09:02 AM
Ammi's Avatar
350 Detroit Muscle
I sent your PM
Old Mar 21, 2004 | 09:21 AM
ZIPPIN's Avatar
Mauja He Mauja
Originally Posted by Ammi
I sent your PM
please share
Old Mar 21, 2004 | 09:55 AM
Ammi's Avatar
350 Detroit Muscle
I will once I hear something back from him.
I'm going to go take his wheel off and go nuts w/ WD-40 to see if it will help any.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
