Gauges
Old Mar 19, 2004 | 11:17 PM
A'sMax's Avatar
Gauges
I want to get some gauges for my 2k but there is nothing what I like for that year , I found some for 02/03. What is the difference between 00/01 and 02/03?
Is it only that 02/03 has extra square hole for trip meter (whatever it is)? Anyone knows? Maybe someone know where to get some gauges for 2k?
Thanks for any information.
Old Mar 20, 2004 | 01:15 AM
FanaticMadMax's Avatar
Well that depends, Since i'm assuming on your current one is an SE. So you see, the 00-01 has white face out gauge on all four. The 02-03 has white gauge on the tach and the speedo but the gas and temp are black facing. Other than the extra hole you mention is the outside temp, DTE (distance to empty gas) and MPG i believe.
Old Mar 20, 2004 | 04:02 AM
A'sMax's Avatar
I want to get aftermarket reverse gauges but they doesn't make it for 2k only for 99 down or 02/03. And I want to know if the gauges for 02/03 will work for me.I dont know if there is any problems with wires or something. The stock ones are so dark
Old Mar 20, 2004 | 02:13 PM
A'sMax's Avatar
any1?
Old Mar 20, 2004 | 02:35 PM
kpr10is's Avatar
yeah, the difference is that hole below the tach. they do make reverse ones for the 00-01, heres the link. they make them for auto tranny but just take out the middle thing for P-R-N-D-2-1, that part isnt indiglo so it shouldnt have any wires attached. enjoy.
http://www.procarparts.com/store-det...00MX%2D7054RGX
Old Mar 20, 2004 | 02:44 PM
A'sMax's Avatar
Thanks for reply but I'm looking for the reverse indiglo ones.........I guess i should keep the silver stock ones.
Old Mar 20, 2004 | 04:34 PM
mad_maxx03's Avatar
I believe that you can use a cluster out of a 02-03, then put on the indiglo gauges. If I'm not mistaken I believe I did read that somewhere before , and don't worry about it not keeping up with your current mileage, its stored in the computer and when you put the new gauge cluster on there everything switches over. Correct me if I'm wrong someone...
Old Mar 20, 2004 | 09:34 PM
† ErV †
nothing switches, the computer throws an error code readable by the consult II only... mileage still works but there is that code deep in the system.
way to get around that is to take apart the cluster and swap all the gauges (speedo, tach, fuel, coolant)..
so basically you are only changing the faces, not any of the circuitry.
Miket2006
Mar 1, 2021 03:55 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
