Drop Resistor Mod
Old Mar 20, 2004 | 01:14 PM
tdogg169's Avatar
Drop Resistor Mod
http://www.cardomain.com/member_page...218989&page=15
I did this to my car today. Has anyone ever did this drop resistor mod the there car?? what does it actually do?? it seems like it just make the car loss the lag when shifting.
Old Mar 21, 2004 | 12:00 AM
aussie983's Avatar
That is all it does.
Old Mar 21, 2004 | 01:30 AM
Jime's Avatar
Hook it up to a WOT switch vs a manual one, its so harsh at part throttle you are liable to damage someting. You can use a manual switch as well but in conjunction with the WOT one.
Just putting it in my 3rd Max now (95 GXE, 97 SE, 2k2 SE) and its a must have mod but get a trans cooler as well to use with it.
Old Mar 21, 2004 | 02:57 AM
5 spd's Avatar
just out of curiosity, this mod just changes the amount of time to shift in an automatic? instead of a smooth shift, it is an abrupt, hard shift?
Old Mar 21, 2004 | 05:02 AM
Jime's Avatar
It actually increases the line pressure to FULL at all times when disconnected.
At part throttle full line pressure produces abrupt hard shifts as you suggest.
At WOT the shift is slower because of the much higher HP being produced.
Old Mar 21, 2004 | 06:25 AM
maxgsxr1
what about installing a resistor with less resistance so the ses light will stay off and the shift would be firm and not hard???anyone look into this?
Old Mar 21, 2004 | 06:28 AM
Jime's Avatar
Yes, even tried a variable.
It seems to have a definite cut off point and as soon as that resistance is reached it switches to full line pressure.
I played quite a long while at this because it made sense to me too.
Old Mar 21, 2004 | 08:04 AM
ckohl23's Avatar
don't do it except for racing conditions and WOT or else your tranny will fall off your car sooner or later. i recommend the valve body recalibration if you want firmer shifts for a daily driver - as long as you don't get the race setup, it's even better for the tranny to get rid of the lag.
Old Mar 22, 2004 | 10:37 AM
tdogg169's Avatar
Thanks for all the input.
jonreidhead
Jan 6, 2016 09:38 AM
knight_yyz
Nov 1, 2015 01:34 PM
maxima-junky
Oct 7, 2015 06:13 PM
Redfox
Sep 28, 2015 10:41 AM
