Having trouble with y-pipe and udp
Old Apr 9, 2004 | 03:37 PM
purekoryo's Avatar
I have a 2000 5spd MAX CALI spec
Y-PIPE:
The recent owner of the car was from upstate NY, so it has had heavy amount of salt, and it DEFINITELY shows. The bolts are rusted...I wanted to ask any of you guys who had the same condition when installing the y-pipe on how you replaced it (the bolts are too rusted that it most than likely needs to have it cut off somehow and i don't know how).
UDP:
I tried turning the bolt on the original crankshaft pulley LEFT, but it will not budge, even while trying to perpendiculary torque it using a 6 ft pipe (probably 250-300ft/lbs of torque). I was wondering how you guys took it off. I'm starting to wonder if it needs to be turned RIGHT to loosen it.
Your inputs would be much appreciated.
Old Apr 9, 2004 | 04:47 PM
BigDogJonx's Avatar
Your problem is you using hand tools. You need to use an impact wrench in this situation. It will get the Crankpulley bolt off and the rusted bolts off in a Jiff. If you dont have them, then you need to get to someone who does, cause you will be there all day trying to crack it loose probably breaking sockets/tools in the process. Been there and no point.
Dixit
Old Apr 9, 2004 | 05:05 PM
purekoryo's Avatar
Dixit
Yes, used impact wrench..still the crankpulley bolt will not come off...
Old Apr 9, 2004 | 06:11 PM
Ammi's Avatar
350 Detroit Muscle
If you can't get the bolt off, I say take it to a shop.
Old Apr 9, 2004 | 07:26 PM
ZIPPIN's Avatar
Mauja He Mauja
whats an impact wrench????
Old Apr 9, 2004 | 07:31 PM
BigDogJonx's Avatar
Maybe your impact wrench only tops out at 200ft lbs. Better impact wrenches put out 450+ft lbs of torque. You will need that.
I had the same problem, my crank pulley wouldnt come of with my 250ftlb impact, then Jay25 came over with his 450ft.lb impact and it tore it off in 15secs.
DBA1999us : impact wrench is the tool most autoshops to use to rip the nuts off the wheels in a jiff.
Dixit
Old Apr 9, 2004 | 09:06 PM
Fezzik's Avatar
You can always blip start (make sure u dont start it) your car. I did that for two of my 5th gen maximas and it worked. The bolt turns counterclockwise to come off. Get a breaker bar and mount it where the bar will either hit the floor (concrete) or hit the lower control arm i think its called. You see when u get under there. But i dented my oil filter a little each time but it got it loose every time.
Old Apr 9, 2004 | 09:45 PM
BigDogJonx's Avatar
Yea I did the blip method. Its easier if someone holds the breaker bar against the lower control arm while someone blips the starter.
Dixit
Old Apr 10, 2004 | 06:17 AM
sascuderi's Avatar
Question:
Since the Y-pipe removes the stock pre-cat, will a local shop install an aftermarket y-pipe for you or not do it beacuse of emmision laws?
Old Apr 10, 2004 | 07:33 AM
purekoryo's Avatar
my local shops are charing $200!...i guess cuz of the rusted bolts? i dont know...but what have u guys paid?
Quickywd01
Sep 21, 2016 09:36 PM
zmcneely13
Sep 26, 2015 02:26 PM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
