WTF Tire wear already
Old Apr 16, 2004 | 10:06 AM
JoeyC502's Avatar
I just rotated my tires for the first time. I have 7k on my max and the outside tread on the front tires are worn down pretty good. My rears still look brand new. I check tire pressure on a regular basis and keep it at 31 psi. Is this normal?
Old Apr 16, 2004 | 10:17 AM
kgb006's Avatar
get an alignment
rotate the tires
hope for the best
Old Apr 16, 2004 | 10:25 AM
irish44j's Avatar
retired moderator
ALIGNMENT...definitely.
Old Apr 16, 2004 | 10:28 AM
vqman
Originally Posted by kgb006
get an alignment
rotate the tires
hope for the best
ya
what he said...
I have 31,000 miles, and I'm already shopping for new tires...
THANK GOD!
I can go out and get some Dunlop SP5000 245/45ZR17's!!!!
-vq
Old Apr 16, 2004 | 10:40 AM
JoeyC502's Avatar
I find it weird that both the fronts are worn on the outside. Is that a characteristic of an alignment. I mean my car tracks perfectly straight when i take my hands off the wheel and my steering wheel is pefectly centered. Just a thought, could it be like that since it is fwd? All the turning and cornering. I would be pretty ****ed if i need an alignment already, the car is still brand new. thanks for the quick responses guys.
Old Apr 16, 2004 | 10:49 AM
Kojiro_FtT's Avatar
Hard cornering could do it, too. How "aggressively" do you drive? When you go to the autocross you are supposed to pump up your tires a bit, cuz otherwise you will actually be driving on the sidewalls during hard cornering.
Old Apr 16, 2004 | 10:57 AM
03maximan's Avatar
Sounds like you're drive pretty hard, if allignment was out, the car wouldn't track straight.
Try taking corners a little slower.
I have 23k miles, rotated about every 6-7k, and still have at least 15k left. These tires aren't that bad, except in the snow they suck.
Old Apr 16, 2004 | 11:09 AM
JoeyC502's Avatar
Not real aggressive at all. I had a an explorer before my max so I was use to slow cornerning. Now that I have the max I take corners a little bit quicker. Maybe i shold increase the psi. Or am i just in denial that i need an alignment. If my alignment is out of wack how can i just target the sidewall tread. The wear seems to be pretty even on both sides. Not one side more than the other. We will get to the bottom of this. Thanks guys.
Old Apr 16, 2004 | 11:15 AM
GeSeKeE19-'s Avatar
Is your car lowered at all? I used to work for goodyear and it seems like If only the outsides are wearing, that can mean camber wear. Alignment and rotation would also help if thats the problem. What we used to do was, flip the tire to even the tread for those that wanted it...meaning, flip the tire on the rim so that the side not as worn is back out on the worn down side.
Old Apr 16, 2004 | 11:21 AM
JoeyC502's Avatar
Nope. Completely stock
Old Apr 16, 2004 | 11:55 AM
kgb006's Avatar
Improper alignment causes excessive tire wear
Old Apr 16, 2004 | 01:07 PM
PWRLFT's Avatar
I say this is normal, mine is all stock and the tires are worn hard on the sides, I think it's from driving like your suppose to with this car. I'll bet anything that you don't have LSD, I'm still trying to get used to handling this cars power, especailly out of the corners. When the wheel is turned, the tire also leans to the side, add no LSD + 255 horses you get uneven wear. I've got my sides worn, and only 10K miles on the car. Keep an ear open for tire spin, if you can cut down on that; the uneven wear will stop.
Old Apr 16, 2004 | 01:32 PM
kratz74's Avatar
I have 34K on originaltires and probably 10K miles left. COuld strecth it to 50K but we'llsee how tread looks before next winter.
Old Apr 16, 2004 | 01:46 PM
maximalex's Avatar
maybe you just got a pair of faulty tires?
Old Apr 16, 2004 | 05:24 PM
Jasonb1982's Avatar
One word: Potenzas!
Old Apr 17, 2004 | 03:14 AM
wdave's Avatar
31 psi is a little low for the front but it sounds like your toe - in is a little too much, not crooked.
Old Apr 17, 2004 | 04:03 AM
itdood's Avatar
Have the alginement checked. Just beacue it tracks straight doen't mean it's in spec. Bad camber or toe will wear tires on inner or outer edges.
I have my Max and another very powerful FWD car, and I've never worn the outer edge on any of my tires. 14k on my Max, rotating the tires every 7500 miles and those are wearing evenly across the tread . If anything, I wear the inner edges on the rear tires of my other car because I have a lot of negative camber on that one for performance.
Old Apr 17, 2004 | 09:44 AM
JoeyC502's Avatar
thanks guys for all the input fellas. Going to have it checked out. What psi are you guys running up front?
Old Apr 19, 2004 | 09:16 AM
Skier's Avatar
I have always ran the fronts at 35 PSI and the rears at 34 PSI. If the car is tracking correctly I'd say alignment is not your issue. My first thought would be under-inflation. Your wear is a symptom of that, especially as it's common to both front tires where the greatest amount of weight resides due to the engine. The opposite (wearing in the middle) is generally an over-inflation issue.
Old Apr 19, 2004 | 10:57 AM
Kojiro_FtT's Avatar
I ran the factory recommended 32 PSI front and rear. I had very even wear on all four tires. Make sure you check the tires cold. If you were running 31 hot then you were real low. Also remember to check your tires when the temperature changes between seasons.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
