Help with SES Code P1320
Old Apr 26, 2004 | 09:54 AM
choosinu's Avatar
I have been reading the board and appreciate your willingness to share information with a novice. I have a 2000 SE with 104K miles. My car has been great. No troubles, just oil changes, brakes and tires. Dealer replaced emissions item under warranty at about 70K.
SES light came on last week so I went to Auto Zone (thanks for that tip). I have seen on this and another site that P1320 generally means coils gone bad. I called dealer to inquire about cost to replace all 6 and change plugs while they were at it. Can you believe they said 700 for the coils and another 175 to replace the plugs. They say they need to do diagnostic, might not be coils, codes are not specific, codes just tell you where to start to look. I hate Dealer Service and I think they, like others in the repair world, take advantage of you when you don't know any better.
I was going to purchase coils and plugs and change them with a friend. What other things might this P1320 code be pointing to? Any advice would be appreciated.
Old Apr 26, 2004 | 11:12 AM
DanL's Avatar
It's usually a bad coil, but can also be the crankshaft position sensor.
If you act fast, you can purchase six coils and six OEM NGK platinium plug
from Jerry Rome Nissan (www.jerryromenissan.com), use the 'sale30'
promo code, and get everything for less than $310 + shipping (list is
$445). You need to purchase them by the end of the month though.
Old Apr 26, 2004 | 11:15 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Pretty sure it's a coil(s), however it could also be:
1)Harness/connector open or short
2)Condensor
However, I'd suspect the coils first and try buying a front AND rear bank coil, new or used, and try swapping one at a time after clearing the code to see if it comes back. Problem with that method is it could be more then one front or rear coil is bad or it's intermittent.
To clear the code, unplug the battery overnight.
To check the condensor, turn the ignition switch OFF, unplug the condensor, turn the ignition switch ON and check for battery voltage. Then check resistance is >1M ohm between two terminals.
Pretty sure you can buy ALL six coils for far less then $700 from DAVEB (888)254-6060.
Old Apr 26, 2004 | 09:22 PM
choosinu's Avatar
Thank you! I placed my order online and am anxiously awaiting the arrival. I can mess this up and start again and still spend less than my local dealer wanted. However, I'm going to do this right the first time.
Old Apr 26, 2004 | 09:24 PM
choosinu's Avatar
2)Condensor
Thank you also. Price was less than half with plugs and shipping included.
Old Apr 26, 2004 | 09:31 PM
TZapper's Avatar
2)Condensor
$700? Where did you get this number from?
Old Apr 27, 2004 | 08:44 AM
twllin's Avatar
damn u shoulda read my thread i was sellin em for 260 shipped to your door
Old Apr 27, 2004 | 12:35 PM
DanL's Avatar
How much extra for the six plugs?
Old Apr 27, 2004 | 02:11 PM
twllin's Avatar
what plugs? thats the set of 6 coils they plug in to the stock wiring nothing else is needed
Old Apr 27, 2004 | 04:18 PM
DanL's Avatar
Go up a half dozen posts or so. $310 for six coils and six OEM NGK platinium plugs. Sorry, thought you were comparing your $260 price to the $310 price and I was wondering how much you sell six plugs for in order to compare apples to apples.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
