MAFs metal net remove or not?
Old Apr 28, 2004 | 08:20 AM
mjk's Avatar
mjk
Head shot!!!
I just got a replacement MAFs for my 3.0L , the assembly has a metal net which i think would restrict the air flow. This is an oem part. Can someone tell me if it would be a good idea to remove that net????
thanx alot
Old Apr 28, 2004 | 08:23 AM
kgb006's Avatar
leave it on
its there for a reason
Old Apr 28, 2004 | 08:34 AM
SR20DEN's Avatar
VQ Wizard
I always remove them.
Old Apr 28, 2004 | 10:36 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i removed it on my old altima and never noticed a difference but when i saw it again on the maxima i just went by this
Old Apr 28, 2004 | 10:43 AM
spirilis's Avatar
Huh, that's really interesting! Looks like mine's staying on
Old Apr 28, 2004 | 10:44 AM
mjk's Avatar
mjk
Head shot!!!
thanks alot everyone, very helpful, but since there weren't any major issues by taking it off. Ill just take it off and hope for an extra 1/4 hp
Old Apr 28, 2004 | 10:49 AM
NCTRNL's Avatar
The screen removal is not a good idea. It will not help your performance. THe screen is there to calm the air flow coming into the motor. The air is very turbulent when it hits the MAF and this will combat that. It is not a good idea to remove that screen.
Old Apr 28, 2004 | 11:37 AM
JdoubleOe703's Avatar
teddibear703
last time i checked my maf, there was some small debris on it like a small leaf... it cant be good having that leaf reach the engine... maybe it catches anything that may have slipped thrugh
Old Apr 28, 2004 | 11:50 AM
NCTRNL's Avatar
Yeah, it definitely does that too.
Old Apr 28, 2004 | 11:57 AM
schmatt's Avatar
What power increase could you possibly hope to gain by removing this screen. All you're doing is removing a second line of defense against damaging your MAF and engine. Is the pseudo performace gain really worth it. I don't think so.
Old Apr 28, 2004 | 05:04 PM
Mike T's Avatar
ignotum per ignotius
The screen is there to smooth the airflow into the MAF. The MAF takes only a sample of the incoming air-flow, it is very important that the air enters the MAF as smoothly and evenly as possible, or the MAF will not get as accurate readings. Every MAF I have seen has these screens, they are not just there to look pretty.
Old Apr 28, 2004 | 05:18 PM
SR20DEN's Avatar
VQ Wizard
Oh dang.
I just had mine powdercoated. They told me it would smooth the flow even more and giv me +10hp.
Old Apr 28, 2004 | 07:52 PM
mjk's Avatar
mjk
Head shot!!!
i have a stillen intake on there and it has a metal cone inside it which is suppose to make the air smooth, so i dunno if i need it. As for it being a second line of defense, if you clean your filter regularly It wont be used. Only some dust settle on that which can get through it anyway. In my setup anyway. What do you guys think?
Old Apr 29, 2004 | 12:10 AM
cobymoby's Avatar
As others have said, the screen is there to smooth the airflow out so that it can get accurate readings. There is a technical term for it but I can't think of it right now.
GM dudes remove their screens as well. They just refer to it as "screenless". Your car probably will make a bit more power, not by air flow, but your car will run a tad leaner and have a hotter burn.
Old Apr 29, 2004 | 02:26 AM
herman's Avatar
Screen before MAF is generally desgined in so that in case nuts/bolts loosens in inside intake box, they will not get sucked in and kill engine. Nissans reason may vary, but this is the general reason in the industry.
Old Apr 29, 2004 | 04:14 AM
Mike T's Avatar
The floor of an airbox on most cars is below the inlet of the MAF, the screen wouldn't get much of a chance to prevent that from happening since the bolts would just roll around on the bottom of the airbox. Not to mention, if that was the purpose of the screen, it should be placed in the inlet of the intake manifold. And you only see the screen on MAF setups, not speed-density...
just my .02
Old Apr 29, 2004 | 05:00 AM
itdood's Avatar
Some actually have honeycombs like this:
All the discussion I've seen over doing this mod is that the MAF will simply measure less air than is actually getting in, that will cause a leaner burn, Especially for a honeycomb equipped MAF. I don't think a screen would have as-much air straightening as a honeycomb so removing it is probably not going to have as much effect.
It's also done on certain turbo charged cars to help prevent a MAF overrun and fuel cut when you up the boost.
Someone posted about a leaf getting caught there....You should find out how the heck a leaf got past the air cleaner.
Old Apr 29, 2004 | 05:29 AM
NCTRNL's Avatar
The screen in my Z28 was a honeycomb like that. It was about a half inch thick. I haven't looked at the one on the Maxima but I just assumed it was the same.
Old Apr 29, 2004 | 06:05 AM
sloppymax's Avatar
the last pic of my homepage is a pic of my new maf. all 5th gens have the same screen just for informational purpose.
Old Apr 29, 2004 | 08:35 AM
mjk's Avatar
mjk
Head shot!!!
Wow, some in-depth info here. Makes me wonder, thanx all
Old Apr 29, 2004 | 09:05 AM
cobymoby's Avatar
The G35 and 350Z however don't have screens. They MAF is also totally different than ours.
Here's a snap:
Old Apr 29, 2004 | 10:32 AM
NCTRNL's Avatar
Probably because they are rear wheel drive, the intake is completely different...
halfpol
Oct 17, 2022 12:16 PM
vingodine
45
May 21, 2016 12:46 PM
jholley
Aug 30, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
