Windows rolling up sloooooow
Hi
My driver side window is rolling up veeery slow, i can hear a squeaking noise, sometimes it stops, sometimes it will go all the way up. No problem with going down. Any ideas? looks like theres a tension between glass & rubber. Any lubricants? what do I do? |
Originally Posted by piotroosh
Hi
My driver side window is rolling up veeery slow, i can hear a squeaking noise, sometimes it stops, sometimes it will go all the way up. No problem with going down. Any ideas? looks like theres a tension between glass & rubber. Any lubricants? what do I do? lower the window, take a wet rag, and rub it up and down in the window track. after it dries, spray silicon spray in the track. DO NOT use something oil based like WD40. roll the window up and down a few times and spray some more in there. all better :thumbsup: |
Yeah i got the same problem on my passanger side window does any1 have any ideas on how to fix this problem..
one last thing.
when the window is down all the way clean the rubber at the top of the door where it meets the glass (the hole where the window goes when down). that helps and also prevents streaking of your window |
Soonerfan.. will try ;-) i'm sure it will help, just wasn't sure what kind of "lubricant" ;-) i should use. will pick up silicone spray later and give it a shot.
here is a pic to show what i mean. sorry the pic isnt the best.
blue - clean red - clean and silicon spray http://images.cardomain.com/member_i...335422_137.jpg |
So u dont have to take the pannel off on the door. And the silicone spray will it stain the window or get it dirty.. So all i have to do is roll the window all the way down and just spray that stuff in the door???
it will not hurt the window. if you do it right it will only be in the track and edge of the window anyway. and thats why i said not to use anything like WD40. it will attract more dirt. you dont spray it in the door. you spray in in the window track. (SEE PIC ABOVE) i spray it in the top and let it run down |
OOh ok i see now the pic helps alot thanks for the pic..
Originally Posted by soonerfan
the window track is dirty.
Originally Posted by dba1999us
ky jelly works well also :naughty:
gotta try that......
yea same here i really wanna try this....
i have some stuff at home that is similar to wd-40 but has silicone in it would that work?
© 2024 MH Sub I, LLC dba Internet Brands
