Please Help!!! Brake Rotors and Pads
Old May 7, 2004 | 07:47 PM
Max20SE00's Avatar
Does anyone know what the replacement #'s for a 2000 NIssan Maxima SE are for rotrs and pads. I purchased Brembo Slotted rotors from automax95 and PBR Ultimate pads. The pads have the number D 1232 RU and they say they replace 109.06530 and number D 712 RU and they replace 109.05400 or 67-D540 The rotors say 43206-4U001 and 08.8065.10 for the rear rotors and 40206-2Y505 and 09.7933.10 for the front. Before I install these I wated to make sure I was sent the right ones. Thanks for any help you guys can give! I couldnt find these numbers on the internet at all or on brembos website. Just wanted to make sure that these will fit!
Old May 7, 2004 | 09:27 PM
panda_1's Avatar
if i were you i would spens bout 150 at blemco and buy the mounting brakcet to upgrade to the 04 maximas 13 inch rotors. my brake change is coming up soon and i will be doing the same.
Old May 8, 2004 | 06:28 AM
optimus1's Avatar
blemco??
I see your short reply, but questions arise from this ...
Are you using same 2000 calipers?
Why go to a heavier rotor and Not a larger or twin piston caliper, also?
I know a heavier rotor will disipate heat better, but will slow or/and give more bump steer and acceleration issues ...
Or is $150 for the new calipers?? (and is that ea or pair?)
Old May 8, 2004 | 07:14 AM
kwd2kSE's Avatar
Here's to the link to Matt's site with all the info you need.
http://www.mattblehm.com/brakes.html
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
