Cold start and screeching sound
Old May 13, 2004 | 11:36 AM
Love_00_Max's Avatar
Lately, I have my car rev up to 2000 RPM during cold start i.e. early in the morning and while reving up it sceeches for some time and then it is OK.
This does not happen when I restart my car when the engine/oil is warm. Should I be concerned -- I checked the IVC and it is OK and no SES light.
Old May 13, 2004 | 03:30 PM
ArMiXiA's Avatar
Yes, lately it's been happening to me too, except my maxima revs up to around 2500rpm just from a cold start and the screeching sound lasts until the engine warms up or about 15 20min. I have check out the engine myself and have not seen anything wrong, also have checked with a body shop and they cant find anything wrong with it either without charging me like $100 for an in depth inspection =\
BTW this is an '01 Maxima
Old May 13, 2004 | 04:03 PM
Rayn4est's Avatar
You have a slipping belt. The rubber doesn't slip when it's warmed up because it contracts and shortens the belt, tightening it...and I suspect the coefficient of friction might even be higher then, too.
Old May 13, 2004 | 06:55 PM
MoMax00's Avatar
Heat expands so im not sure its the belt, BUT my car before my 00 max had that problem and it was because of the powersteering pump they do that when they are ready to go, till they warm up, but im not sure its the same noise as your hearing so just check the fluid and make sure its topped off and try and listen to see if its coming from the pump to make sure.. good luck
Old May 17, 2004 | 11:23 AM
When you mentioned about PS fluid - it immediately rang a bell in my mind. A few months ago I had replaced for the first time the PS fluid to Mobil 1 Syn ATF and the levels were right (cold and hot levels) even as it was screeching.
FYI, the screeching started after more than a month or so after changing to Mobil 1 syn ATF --- over this weekend I replaced the syn fluid with Valvoline ATF (not synthetic) and the screeching is gone.
Man I have had enough with these syn fluids -- no more of syn fluids on my Maxima. I don't know why syn fluids don't work on my maxima -- I would think its water like viscosity of syn fluids compared to thicker viscosity of petroleum based fluids.
On a side not -- I shall stop munking around with my max moving forward unless absolutely necessary.
Old May 17, 2004 | 06:13 PM
mm7759's Avatar
I just had a strange noise happen the other day myself. Not a screeching. Mine sounded like a metal rattle, like something hitting a heat shield or something. It only happened once....so I'm hoping it's just a fluke. If anyone know otherwise.....give a yell!
TheMafia
Sep 4, 2015 08:26 AM
trungg86
Sep 4, 2015 04:58 AM
