Suspension troubles... need help!
Old May 20, 2004 | 09:07 PM
TEEdotMAX's Avatar
i got the teins s-tech illumina set up & i've recently noticed a noise that sounds & looks like the spring on the front driver side is turning whit the strut assembly when i cut hard left turns. i've checked all my nuts & bolts & everything is tight. im not sure what's going on here. i need some ideas.
i was also in an accident about a month ago in which i jumped a curb. i think that this may have some play into my problem also.
Old May 21, 2004 | 12:14 AM
JdoubleOe703's Avatar
teddibear703
sounds like your strut bearing broke off and now when u turn your wheel the whole spring turns and grinds because the bearing is gone...
Old May 21, 2004 | 12:15 AM
teddibear703
the strut bearing sits ontop of the strut.... its grey and black, looks like a doughnut and is made of plastic, nissan cheaped out and due to the extra force from lowering your car, they break off easily...
Old May 21, 2004 | 08:25 AM
TEEdotMAX's Avatar
i know what ur talking about... that would make sense. thanks for the suggestion. i'll check it out today
Old May 21, 2004 | 08:56 AM
Dohcser's Avatar
TEED,
I am experiencing the same symptoms after my Koni and Tein install. Please post your findings if possible.
Old May 27, 2004 | 08:50 PM
TEEdotMAX's Avatar
Originally Posted by Dohcser
TEED,
Sorry about the very late response but I finallly got some time to work on the suspension. The strut bearings were the culprit of my strange noises. They were cracked pretty bad. I bought new ones from the dealer for about $18 each & replaced them. my suspension is as good as new now!!! thanks for the help teddibear!
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
