Differences Between Y Pipes?
Old May 25, 2004 | 03:24 AM
MoMax00's Avatar
just wanna know soon ill be in the market for a y pipe so is there a difference between different companys Y Pipes? tkx
Old May 25, 2004 | 04:04 AM
Kiosk's Avatar
Some claim higher quality and better fit but I recently bought the "cheaper" one from Warpspeed for 200 bux (instead of 350-400 like some others) and I had no problems with fit, installed it myself also and the quality looked fine. good bang for the buck considering the performance increase....
I think the basic qualities you want are mandrel bent tubing and aluminized steel......good luck
Old May 25, 2004 | 01:01 PM
MoMax00's Avatar
tkx for the help and also about how much performance increase do u feel with it? just wanna know.
Old May 25, 2004 | 02:13 PM
Kiosk's Avatar
I already had an intake so the y-pipe complemented that, i fell a pretty good increase specially after 3-4k rpms you can feel quite a different pull than from the stock pipe and it screams at 5k+ rpms!
good luck
Old May 26, 2004 | 07:07 PM
MoMax00's Avatar
i been reading alittle on budget y pipes and the fact that they are cheapiest and work the same i am thinking of going with budget anyone have a site so i can read alittle from budget.
Old May 27, 2004 | 02:42 AM
MAX0830's Avatar
take it from me i did a ton of research and thought it would be fine to put one of the cheaper pipes (warpspeed) on the car. first the quality is just not there. actually its horrible. secondly you have to remove the cross memeber from the undercarriage of the car. its there for a reason.. the flex section was tiny and ended up leaking. and lastly it hung so low to the ground if my car was lowered i know for sure this thing would be grounding out. i then got so fed up with it that i bought the cattman y pipe. yes i did have to relocate the O2 sensor but even with that this y pipe was built so nice the welds are beautiful and the fitment its great there is a hanger that you can use to hold it up and the second you take it out of the box you know its much much better then the other cheaper knockoff. its just my 2 cents but trust me buy the cattman pipe i know its more money but you dont want to be like me spending the money twice
Old May 27, 2004 | 05:24 AM
nailz420's Avatar
I was thinking the same thing - you get what you pay for. But I was wondering, do you have any dyno data on the Cattman pipe? I am interested if there are any increases before the 3,000 rpm line.
Old May 27, 2004 | 05:43 AM
ihavea5spd's Avatar
why is it that people STILL have to relocate the o2 sensor on the cattman pipe? is there a reason this hasn't been fixed yet?
Old May 27, 2004 | 06:58 AM
Jay93SE's Avatar
maybe someone needs to contact Dallas at Warpspeed and volunteer their car for a new y-pipe design. It seems like the 5th gens and some 4th gens have the biggest problems with their stuff. 3rd gen guy's don't seem to have any problems with Warpspeed. just my .02!
Old May 27, 2004 | 08:47 AM
Ephraim's Avatar
about 2 months ago i had an order for the cattman catback exhaust, and Cattman called me to see if i have a fed or cali spec car
so they make a fed or cali spec catback exhaust, im guessing they will do the same to the ypipe soon too.
Old May 27, 2004 | 12:17 PM
2k1seae's Avatar
I just got a Cattman Y-Pipe from SWA. They ask if you are a fed spec or a calli spec. The cali spec is very different from the fed spec, requires the removal of a pre cat and has O2 bung on it. I'm not sure what is meant by relocating the O2 sensor. I hope to install mine this week end if I can get the car high enough to work under it and can get the bolts off.
Old May 27, 2004 | 04:07 PM
MoMax00's Avatar
anyone with a budget y pipe have problems with it being too low under the car, like the warpspeed?
Old May 27, 2004 | 05:01 PM
Larrio's Avatar
The Definitive AE Master
man, u guys are just giving each other the wrong information. Cattman already makes a fed spec and cali spec y-pipe. A quick look at www.cattman.com will yield you the results. Also, it would make no sense to ask for a cali spec or fed spec for the exhaust
cattman is made of stainless steel (www.cattman.com)
budget is made of stainless steel (www.budgetexhaust.com/)
stillen is made of some sort of steel, but ceramic coated (www.southwestautoworks.com) It comes with a second piece, extended for maxima with federal emissions.
warpspeed is made of aluminized steel (www.warpspeedperformance.com)
Old May 28, 2004 | 06:59 PM
max_pusher's Avatar
How much gains are you suppose to gain with the Y-pipes? Are the 5th generations getting about the same hp and torque increase ascompared to the 4th generations?
Old May 28, 2004 | 08:35 PM
Larrio's Avatar
there is no definite gains as cars/engine vary in degrees from vehicle to vehicle.
i guess a safe estimation would be 10-15 whp
Old May 29, 2004 | 10:08 PM
thomasd cook's Avatar
How is the O2 sensor relocated? Dou you have to add on to the wire, or drill a hole for it to go into the new Y-pipe?
Old May 29, 2004 | 11:16 PM
panda_1's Avatar
i agree with the rest of the guys,, i also went with a warpspeed y and it compliments the berk. i hit top end with the quickness, and it gives a very suddle exhaust note.
Old May 30, 2004 | 03:15 PM
Kiosk's Avatar
A lot people here talking about the warpspeed hanging low and removing crossmember, I just installed my warpspeed pipe last week and its not low and didnt have to remove any crossmember.....guess some depends on your experience, I didnt have any fit or other problem. Good luck!
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
doctorpullit
Dec 12, 2015 09:39 AM
