Lost Power to Bose Sub Amp
Old Mar 27, 2001 | 07:28 AM
idn09
I lost power to my Bose Sub Amp mounted underneath on the right of the sub. I am pretty sure it's the fuse but I can't locate the fuse. Does anybody know where the fuse box is so I can get replacement..or am I just a lost cause !!
harshal@indify.org
Old Mar 29, 2001 | 06:58 PM
virginia2001's Avatar
If it's just the Bose sub woofer, check fuse #67 (15A fuse) in the J/B fuse block... I think this is the fuse block behind the door at your left knee (as you sit in the driver's seat). If the fuse is OK, check for positive battery voltage at terminal 48 of the woofer.
Old Mar 29, 2001 | 07:09 PM
wrong fuse box location
I told you wrong, the fuse box is next to the battery. You should see two "AUDIO" fuses on the cover. #56 powers everything but the woofer, #67 powers the woofer.
Good luck.
Old Mar 30, 2001 | 06:40 AM
idn09
Re: wrong fuse box location
Thanks virginia2001
I will check as soon as I get off of work...I think I already checked it and the fuse was fine...there is an audio fuse and a speaker fuse right next to the battery..and both of those seemed to work fine...I think I might have either blown the amp or the woofer..either which is not good news..i'll let you know..once again though thanks.
idn09
Mar 12, 2020 12:06 AM
Bluenissan
Sep 20, 2015 08:54 PM
popdedop
Sep 11, 2015 11:17 AM
