what does your car idle at?
Old Jun 19, 2004 | 08:38 AM
Jackboot's Avatar
when in park and when in drive.
mine idles at about 1100-1200 in park and about 700 in drive. is this normal i never really paid attention to the rpms.
Old Jun 19, 2004 | 09:21 AM
Jackboot's Avatar
actually i just drove around a bit and it was idleing at about 700 in drive too...
Old Jun 19, 2004 | 09:43 AM
MaximaPolak's Avatar
1200???? Thats definately not right.....
My idle is messed up (cause i cleaned the TB) and it's only at 900
Old Jun 19, 2004 | 10:55 AM
slickrick's Avatar
600-750 depending on the weather and engine temp.
Old Jun 19, 2004 | 12:43 PM
scopium
before i had my ypipe my car used to idle at 600-700 but after the install its been idleing at 1000-1200
Old Jun 19, 2004 | 12:47 PM
NYPD-Arnold's Avatar
Z
Mine idles at 1200 when in Park too...
Old Jun 19, 2004 | 01:02 PM
Jackboot's Avatar
[QUOTE=Arnold K.]Mine idles at 1200 when in Park too...[/QUOTE
did you drive it around or did you just go to your car and turn it on and see what it was idleing at? cause when i first turned mine on it was at like 1100 but then it went down to about 600-700 shortly after...
Old Jun 19, 2004 | 01:11 PM
Z
Just turned it on for a few seconds.
Old Jun 19, 2004 | 02:03 PM
sascuderi's Avatar
Fully warm, sitting at a light in drive with foot on the brake....I'm always 700 RPMs on the nose!
Old Jun 19, 2004 | 03:47 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Its always going to idle higher when cold, its due to the way the engine computer is programmed to quickly bring up the engine to warm operating temeperature where everything wears less inside the engine. Mine idles at 800RPM in neutral and its a 5spd. I programmed it like that with the Consult- Nissan scan tool
Old Jun 19, 2004 | 05:25 PM
celica's Avatar
if its the high idle code do the idle learning process ( couldn't get it to work) or jus unplug the neg battery cable overnight and it shall reset and idle back at 700 ( did this and worked for me this week)
Old Jun 19, 2004 | 05:41 PM
MaxedOut's Avatar
when in neutral i idle at 400... sometimesafter driving alot.. when is top for a second my idle dips to 350.. is that tooo low for a manual?
Old Jun 19, 2004 | 05:52 PM
celica's Avatar
that don't sound right ither your tb need cleanin or u need a tune up or soemthin
my auto use to idle at 500 rpms before i cleaned the tb so manual should be a little lower so that might be your problem
Old Jun 19, 2004 | 06:02 PM
MoMax00's Avatar
mine idles at about 500 and less i was wondering if there was somthign wrong with it its funny when i put my A/C on my idle jumps up to like 750 and seems to be much better response with the A/C on its wierd any suggestions would help if someoen has had this problem and knows to fix that be much better. tkx
Old Jun 19, 2004 | 06:49 PM
Autos idle lower than 5spds, per FSM. With the AC on the IAC kicks up in duty cycle and keeps the engine runing. A/C puts alot of drag on the engine- and it don't make alot of power at idle so they need to kick up the RPMS in order to keep it runing with the A/C. Mine idles soo smooth ya cant even tell its runing other than the nasty smell and rumble from the exhaust. 800RPM +/- 15RPMS per Consult- veryyy stable engine.
Old Jun 19, 2004 | 07:06 PM
crispykid717's Avatar
Bigger than Jesus
Mine idles at about 1200rpm or so right on start up. Then it slowly drops to a final spot of ~800rpm
Old Jun 19, 2004 | 09:38 PM
MaxedOut's Avatar
ok i was int he car the other day.. when i was idle in neutral with nothign on it idled at 375..
then i had the ac on it moved up to 425.. thats about it
so maybe i should clean my tb? oh btw the engine was already warmed up and stuff.. when its cold it idles aroun 700-800
i'll drive around again and see whats up later
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
doobadoo
Aug 15, 2015 06:43 PM
Maxboy23
Aug 11, 2015 11:59 AM
