Hawk brakes installed.
Old Jun 25, 2004 | 05:10 AM
Neeferea's Avatar
I put hawk brakes in, but they sound very loud, squaking sounds all the time. May be the reason to the sound are rotors?
Old Jun 25, 2004 | 10:00 AM
2k3TitaniumSe's Avatar
I heard that the hawks are garbage. GreekMaxima had them and took them off the same week.
Old Jun 25, 2004 | 11:09 AM
scopium
there might be a brake in period... i've never used hawk..
raybestos QS or even stock pads are the best ones.. imo
Old Jun 25, 2004 | 02:05 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I use Hawk with powerslot....believe no difference form stock..
Old Jun 25, 2004 | 04:04 PM
1FSTMAX's Avatar
Which hawk pad? The HP or HP+?
Old Jun 25, 2004 | 09:34 PM
Ben's Avatar
Ben
I use the Hawk HP with brembo blanks.
It is louder than stock but well worth it.
Stay away from the HP+ unless you are autocrossing or road racing.
Old Jun 26, 2004 | 03:42 AM
Virus's Avatar
Stay away from the Raybestos QS pads also. I bought them because everyone regarded them as being of high quality and quiet. They are neither. Buy OEM pads from DAVEB. I bought QS's for the front and OEM's for the rear and the OEM's are quiet and smooth. The QS's squeal at times and droan every time I break.
Old Jun 26, 2004 | 03:46 AM
Ammi's Avatar
350 Detroit Muscle
I've used Hawk pads once and I will never use them again. If it's not too much trouble, replace them.
Old Jun 27, 2004 | 02:19 PM
Jer's Avatar
Jer
I'm on Hawk HP+'s and I love 'em.. the car stops better than anything else
Old Jun 27, 2004 | 02:38 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
I went through my 2nd set of OEM pads- not the key value crap in 15K miles- I drive my car verry hard and road race it every once in a while. OEM pads where warping my stock rotors all the time. I switched to Hawk HPS from Tire Rack at around 53K miles and repleaced them again at around 72K miles along with some Akebono Ceramic pads on the rear with EBC Grooved and Dimpled rotors- from Tire Rack. EBC rotors took about 3 weeks to finally break in and they still don't stop as good as OEM rotors did. I get green fade after a few consecutive high speed stops, where my OEM rotors bit harder and harder the hotter they got. I love my HPS pads... read the instructions on how to break them in.
Old Jun 27, 2004 | 11:58 PM
ajahearn's Avatar
This post isn't going to help as there doesn't appear to be a clear winner here but I'll my data point. I use the Hawk HP+ with Stillen x-drilled. No problems other than dusting. When I changed the rotors I adhered to the Stillen guide which said to use new pads. The kit I bought included Axxis metal masters so I used those. I took them off about 3 weeks later because they made far too much noise. I put back the HP+ and its been fine so far (10k+ miles). I'd buy the Hawks again.
I have used Axxis metal masters if someone is interested (for a price).
Old Jun 28, 2004 | 06:12 AM
F23A4's Avatar
I have Hawk pad with my powerslots. BIG MISTAKE!! The things squeaked from day 1 and they're carving up my rotors.
As soon as I have time I'll get the Raybestos pads. (Hopefully, my powerslots arent damaged as well.)
Total disaster!!
Old Jun 28, 2004 | 07:02 PM
Mike T's Avatar
ignotum per ignotius
I'm assuming everyone here had properly bedded the pads before normal use, as Hawk requires.
I haven't tried the Hawks on my Max, but on the Supra they were awesome, as in you could feel the G forces tugging on your eye ***** if you jammed the brakes at 80mph. But the 12.7" f&r rotors might have helped a little...
Old Jun 28, 2004 | 07:23 PM
E55AMG2's Avatar
Wat
I had the Hawk HP+ on the front (hps in rear cause they dont get hot enough to warrant HP+ pads) and they worked really well with Powerslots. I did a 60-0 stop stock was like 115, and after the new pads and rotors it was cut down to 88 ft. The downside was that they squeal like all hell unless you have them up to race temps and they NEVER stop grinding. They did no damage to the rotor, but Id not recommend them for street use.
Old Jun 29, 2004 | 05:20 AM
Neeferea's Avatar
I see, so squealing is normal... It explanes why after HIghway races they stoped making sounds.
Old Jun 29, 2004 | 05:00 PM
E55AMG2's Avatar
Wat
Also, they dont have the loops that the stock pads have, so they wiggle a bit, and that also causes them to squeal.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
