dealer tells me FRAM air filter is dangerous
While getting service done and the dealership, the service rep told me they noticed I was using a FRAM air filter (sorry, no fancy intake yet on my car). She went on to tell me that they have had some major issues with people using non-nissan brand air filters, 'all these people going to Jiffy Lube for service are getting these air filters and they don't fit correctly allowing damage to the intake system'.
Is this a bunch of BS or what? Not that the stock air filter cost any more but it this just another ploy to scare people into having the dealer service their car?
Later!
NitDawg
Later!
NitDawg
Originally Posted by 2k3TitaniumSe
Their oil filters are great. What are you talking about. It's has superb filtraton.
Fram oil filters have been shown to literally fall apart inside the metal container. They use plastic bypass valves that are GLUED to the endcap and cardboard endcaps. I have YET to see black and white tested facts that they have decent filtration. Its all marketing and zero performance. Plus its a Allied Signal/Honeywell product...el shiitah
I was even told by the autozone guys (as I was buying my mobil 1 oil filter) that they have seen and heard of fram oil filters collapsing on themselves. This could be so bad that your engine could lock up due to lack of oil. just pay the extra amount and get mobil 1 and a CAI or WAI.
Originally Posted by NitDawg
So maybe the FRAM oil filter sucks, but what about an air filter? What are people using for stock air intake replacement filter??
ANYWAY the fram, like most other filers, is a good replacement air filter......
The dealer
you.......you can put in any filter you want.....(although some dealers say that K&N voids the warranty that is total
) THESE ARE DIRECT REPLACEMENT FILTERS.
If I was stock, I would use the OEM filters they are not expensive and easy to get (for me). But I have a PR intake with a K&N and I use Mobil 1 synthetic, so I stay true to the brand a use Mobil 1 filter as well.
And the reason service mgr told you not to use anything other than OEM is because of MAF problems usually because of oiled type filters.
My service tech showed me a list that they had been compiling of fram filterering media getting caught in the VTC gear. (oil filters) Their paper air filters are fine as are most paper filters. They generally fit decent. The folks in the mustang forumns have pretty good experience with fram filters going bad. The fram double guard is actually the same filter as their regular one, with a stonger more solid feeling outer shell. Same crappy plastic and cardboard innerds.
Originally Posted by tdogg169
When my first maf went out, my dealer told me that he was getting alot of people coming in with there maf going out with fram air filters.
BTW, does anybody know who makes the Mobil 1 oil filters? My Grandpa used to work for Mobil and stays pretty up to date with things, he was telling me that he can almost guarantee that Mobil does not make the filters. They better be a good filter because thay are twice as expensive as any other filters I have seen.
here is a nice oil filter study to look at, i'm shure some ppls have seen this b4.
click here - > http://www.scuderiaciriani.com/rx7/oil_filter_study/
Originally Posted by MaximaPolak
I also use fram oil filters....This one for that matter..
Teflon will work great for gears, like a rear diff in an f150, but it will breakdown at high temps in you engine and it WILL clog up the oil lines.
hah I used FRAM for a decade with no problems. The first time I use a K&N oil filter it gets clogged. Going to get fram again next time... There's a reason Fram is the top-selling brand...and I doubt that's because it sucks....
it is widely known that fram oil filters suck. im not going to say use this or that.....but please dont use fram...do it for your maxima.
Originally Posted by NewLoveI30
Probably because people remove their intakes and replace with stock and a fram filter before going in for warrantee work! LOL.
As for using an air filter, I have found MANY air filters that really come really close, but dont quite fit 100% correct. I use the OEM Nissan Air filter...yeah..I pay about 5 bucks more...but I dont have to worry about fit. I have found this also to be true in my wifes Ford Focus....the filter just doesnt seal quite right.
PLEASE, DO NOT USE THAT FITER IN YOUR MAX, NOT JUST BECAUSE IT'S FRAM, BUT BECAUSE TEFLON HAS NO PLACE IN THE ENGINE!!!
When network wires are run in ceilings, the cable must be "plenum" rated which means the jacket is made of teflon. They do that for fire code because teflon has such a high melting point and it will not burn on its own.
I've used all sorts of filters incuding fram over the years and never had a problem with any of them. For whatever reason, Fram has become the whipping boy of filters on the Internet and it's all based on hear-say. I think the rumors were started by Purolator.
Later!
NitDawg
Later!
NitDawg
BS BS BS BS BS BS BS BS BS BS BS BS BS BS! Man I am so tired of stupid trained monkey Nissan service advisors pulling some ignorant $hit out of nowhere. I had a K&N filter while my car was knocking and pinging (it was the infamous coilpacks) They told me it was the oil in the K&N and that the K&N didn't fit properly allowing dust particles to pass the filter and strike the MAF. I said "so you mean to tell me this $30,000 car is that picky over an air filter?" Get real. What is funny is the factory Nissan filter is oil impregnated! Now how does that oil stay off of the MAF, but yet the K&N's oil doesn't? Man here's some cheap advise, don't ever listen to what the Nissan service advisor says. Get on the ORG, at least you'll get some honesty. I had one tell me the other day that it was going to cost $60 to turn my SES light off ( I did a radiator flush and started the car up with the electric unplugged) He told me thats the only way that light will go off. I posted an add on the ORG was told to leave the neg terminal off of the battery overnight, and what do you know the light was off. Well at least I know if I fail at everything else in life, I can always be a Nissan service advisor and hand out BS excuses all day. By the way I use the napa Gold filter, with the anti drain back valve. I use Mobile 1 and change the oil every 5,000.
Originally Posted by Lytheum
anyone have a hard time getting the k&n air filter to fit right? getting it back into the air box was a job. no way i am taking it out again till i get an intake
2002 nissan maxima, here buying air filters from courtsey nissan parts.. good filters or should i go to the dealer, damn it.. i have a farm air filter in the maxima.. i dont care if farm is good or bad, i need a replacement air filter where do i get it, where i buy, whats the website. how much.. solutions people , solutions.. i have a farm. i need help!! lol
IMO the biggest issue with the MAF deal is not from stock K&N installs but people cleaning/re-oiling their filter and not letting it dry out first or using too much oil. Also, some El Cheapo (tm) eBay's Best (tm) intakes come with crappy, junky "pre-oiled" filters that I wouldn't put on a lawn mower.
All air filters pass dirt, no air filter is 100% efficient at blocking particles (if it were, it would block all airflow, period!) The amount of dirt that "slips through" the air filter is too small and too light to be causing serious damage, and it's almost always blown out the exhaust valves well before it can settle into the cylinder and possibly slip by the rings.
I'm far more worried about what damage that damn throttle plate screw is going to do when it falls out and tanks my VQ...
If I ever see a legitimate case of engine failure linked directly to using a cheap air filter I will change my mind!
With drop-in K&N i have had zero fitment or MAF issues. It fits perfectly and a visual of the MAF after 10k miles revealed no oil or sludge that I could tell.
As an aside, Hot Rod flowed K&Ns etc. awhile back and found that they do let more dirt into the engine than OEM filters. Increased air flow = less filtration efficiency.
Originally Posted by itdood
Teflon has the highest thermal stability of any plastic. It's melting point is about 500^f. It can survive just fine @ a continuous operating temp of 400^f. If your engine's oil is getting above 400^f, you've got other problems the least of which is teflon. Oil temp is typically ~ 230^F which is half of teflon's melting point. Teflon is also extremely stable all the way up to it's melting point and can run continuously without breakdown @ 400^f. When it does break down it releases stuff that is probably dissovable in oil.
Originally Posted by Virus
I have oem air boses on my vehicles and use K&N stock replacement filters with no problems.
I also drove a Buick Regal wagon for over 200,000 miles over 14 years using Fram filters & never experienced any problems.
Mr. P
Mr. P
