TCS and SLIP light on at the same time...
Old Mar 31, 2001 | 12:04 PM
Max_Vader_2K's Avatar
have any of you had this happen before. I was crusin downtown Nashville, TN and I looked down and seen both of thoes lights were on. When I got to a light I stoped the car and restarted it and the lights went off and never came back on. What did that mean??
Old Mar 31, 2001 | 01:02 PM
RBa's Avatar
RBa
If it does that again, bring it in to the dealer to get it serviced. There should be a TSB for this problem.
Old Mar 31, 2001 | 02:47 PM
Loe max's Avatar
-Indicator light
If a malfunction occures in the traction control system, the SLIP and the TCS OFF indicator lights come on in the meter panel. As long as these warning lights are on, the traction control function is canceled. The vehicle will behave like a model without the traction control system. This malfunction can run anywhere from the fuse, wires or the brain of the system. Assuming you bought the car with a warrenty, this should be covered under the 3year/36,000 basic warranty.
Old Mar 31, 2001 | 08:02 PM
Ok
I will take it to the dealer and get it check out
Thanks.
Old Apr 1, 2001 | 03:12 AM
RBa's Avatar
RBa
Re: Ok
Try http://www.nhtsa.dot.gov/ for the TSB. I'm not sure but try anyway. They might have one for this problem. This way you wont have to go through a hassle at the dealer.
Old Apr 1, 2001 | 02:18 PM
MaineI30's Avatar
Re: Ok
Thanks.
I've had this happen in conjunction with my ECM problem -- TCS light, SES light, and SLIP light at the same time. They're currently blaming my ECM harness, who knows.. will post when we figure it out.
/aac
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxie40
Sep 14, 2015 11:28 AM
