Oil drain bolt ?
Oil drain bolt ?
Did an oil change 2K miles ago and went on a 1500 mile trip. Got back and parked in the garage for 2 days and noticed spot of oil about 2" across. Checked under car and its slowly dripping out of drain bolt. Is the bolt stripped or could it be the crush ring (Ive never changed the cruch ring since the car was new and it had 36K miles). Car was abotu 1/2 qt low after 2K miles so the drip isn't terrible but I'd like it to be fixed. IS this a common issue with 2k2 Maximas?
Get it from DaveB @ Southpoint Nissan in Texas at 888-254-6060 or at Courtesy parts: http://courtesyparts.com/A32_maint.html
If you're going to pull the drain plug, why not install a drain valve? I installed the Fram and really like it when changing oil. It's brass, with a rubber gasket so it seals well and no more hot oil on the hand. The Fumato is probably better quality but costs more. I paid ~$15 for a Fram SD3 and liked it so well I installed another one on my pickup.
Enlighten me on the drain valve thing. I have no clue what you are talking about. Ive probably done literally 100-150 oil changes and have never heard of this term. Is it something so you leave the bolt in and somehow "bleed" the oil w/o removing the bolt?
Originally Posted by Y2KSESteve
On the Fram filters its a tube you drain the oil from without having to remove the filter...
http://www.thetoolwarehouse.net/shop/MIT-7201.html
litch
123
Jan 4, 2024 07:01 PM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
