Is traction control for 2002-2003 the same as HLSD?
Old Jul 4, 2004 | 12:44 PM
MikeD95SE's Avatar
If not how can I find out if my 2003 SE has HLSD?
It doesnt have traction control.
Thanks,
Mike
Old Jul 4, 2004 | 02:23 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
HLSD cars have aluminum pedals.
Old Jul 4, 2004 | 03:15 PM
MikeD95SE's Avatar
Sweet.. So just because I dont have traction control that doesnt mean I dont have HLSD cause I dont have traction contol but i do have aluminum pedals... I thought that was part of the titanium package...
Thanks,
Mike
Old Jul 4, 2004 | 06:06 PM
6spds didn't come with traction control, nor did the 5spds. Acura CL- Type S 6spd didn't come with traction controll eighter- I acutally like that car. Yet I wear a Nissan tattoo - no questioning me bout Nissan diehardness
Old Jul 4, 2004 | 06:41 PM
Zero Deuce SE's Avatar
Thanks,
Mike
Do you have pedals like these? This is maximillion's car.
Old Jul 4, 2004 | 06:58 PM
Damn the interior looks awesome Best Maxima interior ever made hands down.... fuggly *** 6th gen.
Old Jul 5, 2004 | 05:31 AM
MikeD95SE's Avatar
Yes, I have those exact pedals...
Thanks,
Mike
Old Jul 5, 2004 | 08:24 AM
silvermax2k2's Avatar
just because you have drilled metal pedals does not mean that you have HSLD.
Also, Traction control is much diffrent then HLSD.
the only true way to find out if you have HLSD is to have the dealer do a vin search for you too see if your car came with it. also, if your car was one of the first bunch off of the production line when they first relased the maxima, you do not have hlsd.
-Chris
Old Jul 5, 2004 | 09:42 AM
6spmax's Avatar
-Chris
I think you're wrong about your first statement, unless it was applied to the first 3 or so months the car was made where HLSD wasn't available.
Also, another quick and definite way to to find out if you have it, is to look at the small plate in the egine compartment on the firewall on the driver's side. If the transaxle code has an 'H' in it, you have HLSD, if it doesn't have the 'H', you don't.
Old Jul 5, 2004 | 10:36 AM
Larrio's Avatar
The Definitive AE Master
traction control is electronic and works by cutting power so that you reduce spin when you lose traction.
lsd is mechanical and reduces spin by locking up the differential when one tire loses traction.
Old Jul 5, 2004 | 01:40 PM
MikeD95SE's Avatar
Doesnt LSD also transfer the lost power from one wheel to the other wheel with traction?
Was hlsd an option? Does the dealer ask you if you want it or does it just come in some cars and not in others?
Thanks,
Mike
Old Jul 5, 2004 | 05:27 PM
6spmax's Avatar
Thanks,
Mike
The dealer won't ask you if you want HLSD because 99% of the time, he won't know what it is. And it was only factory installed on mostly loaded models.
Old Jul 6, 2004 | 12:36 AM
cobymoby's Avatar
LSD is in your tranny. Like larrio said, it is a mecahnical way of distributing power to both wheels instead of just one like an open diff would.
Traction control is controlled via the ECU through speed sensors similar to ABS sesors. When it detects that one of the wheels is losing traction then it closes the TB for a split second.
It's nothing more than a computer controlled back peddal. When you are losing traction you just lift of the gas for a split second and mash it again. Watch NHRA drag racing and you'll see what it is.
Old Jul 6, 2004 | 08:17 AM
Larrio's Avatar
Thanks,
Mike
LSD's do transfer power when one wheel loses traction and locks up your differential so that the other tire can distribute that power evenly.
traction control CUTS power when it detects a loss of traction.
Old Jul 6, 2004 | 08:34 AM
SR20DEN's Avatar
VQ Wizard
For the gazillionth time...
On the firewall under the hood of your car there is a little aluminum plate that has the VIN and some other codes. It says VQ35(DE) for the engine and for the transmission it will list one of the following,
RS6F51A (for NO HLSD)
RS6F51H (for HLSD)
Old Jul 6, 2004 | 09:58 AM
MikeD95SE's Avatar
Thanks guys... I have it I appreciate all the help.
Mike
Old Jul 6, 2004 | 04:18 PM
Maxnut's Avatar
does HLSD come on autos?
Old Jul 6, 2004 | 05:02 PM
kklier's Avatar
NO!
And those drilled metal pedals where only offered stock with 6speed MT transmissions equiped with HLSD( 2002-2003).
Old Jul 6, 2004 | 05:08 PM
kklier's Avatar
NO!
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
