P0011 + P0456 - Has anyone had these codes
Old Jul 9, 2004 | 05:31 AM
black-maxim's Avatar
P0011 : Camshaft Position Actuator A - Bank 1 Timing Over Advan.
P0456 : EVAP Emission Control System Leak Very Small
63k miles, 2002, AT
This scares me a little. I just changed O2 sensor and MAF two weeks ago. What's wrong with my car?
Old Jul 9, 2004 | 09:15 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Yikes~!
I don't like the sound of that first one, since it's related to your Intake Valve Timing control.
You should see if that crank sensor TSB applies to your VIN.
Old Jul 9, 2004 | 09:16 AM
IceY2K1's Avatar
FSM possible cause:
- Harness or connectors
(Intake valve timing control solenoid
valve circuit is open or shorted.)
- Intake valve timing control solenoid
valve
- Crankshaft position sensor (POS)
- Camshaft position sensor (PHASE)
- Accumulation of debris to the signal
Old Jul 9, 2004 | 09:18 AM
IceY2K1's Avatar
DTC Detecting Condition:
There is a gap between angle of target and
phase-control angle degree.
Fail-Safe Mode:
When malfunction A or B is detected, the ECM enters fail-safe mode and the MIL lights up.
Intake valve timing control The signal is not energized to the solenoid valve and the valve control does not function.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
