Cross-Bar Removed- GOOD or BAD?
Old Jul 20, 2004 | 08:00 PM
Trance Artur's Avatar
Removing the cross-bar from under the exhaust. Is that good or bad?
Old Jul 21, 2004 | 02:19 AM
Triple8Sol's Avatar
I miss the .org!
I removed the one under the Y-pipe, since the Warpspeed pipe fits like a$$ and hangs too low. Seems ok?
Old Jul 21, 2004 | 06:48 PM
maximadave's Avatar
detailerdaveb@gmail.com
took mine off too. rubbing problems on hard accelleration.
Old Jul 21, 2004 | 07:05 PM
irish44j's Avatar
retired moderator
wouldn't that take stiffness away from the frame?
Old Jul 21, 2004 | 07:07 PM
2k2kev's Avatar
It's chrome alright...
why do you want to do it?
Old Jul 22, 2004 | 07:35 AM
nm's Avatar
nm
I think that's exactly what it's for. Mine is off right now but I'm gonna get some spacers and longer bolts (of appropriate type for a frame brace) and put it back on.
Old Jul 22, 2004 | 11:12 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i did the same thing but finally removed it because of rubbing durning hard acceleration while turning even with it lowered.
Old Jul 22, 2004 | 11:16 AM
nm's Avatar
nm
By how much did you lower it? I was going to lower it by .75".
Old Jul 22, 2004 | 11:29 AM
Maxima Dan's Avatar
Mine's been off for a couple of months now, thanks to the WS Y-pipe that hangs too low and bumps on it. I can't really say I miss the crossmember. In fact, I can't tell that it is gone.
Old Jul 22, 2004 | 11:30 AM
UMD_MaxSE's Avatar
Got Bent?
rubber or metal washers with longer screws could help...
Old Jul 22, 2004 | 12:23 PM
NewLoveI30's Avatar
I never had a crossmember under my Y-pipe, only under the B-pipe.
Wierd?
Old Jul 22, 2004 | 01:02 PM
scopium
if your gonna put washers.. you're gonna need about 8 washers for each bolt..
once u press accelerate ... that thing flexes down for about 1.5 inches
Old Jul 22, 2004 | 01:15 PM
Maxima Dan's Avatar
Wierd?
It's not under the Y pipe, it's under the B, but right after the main CAT.
Old Jul 22, 2004 | 02:11 PM
MaxSE2k's Avatar
Get poly motor mounts, it won't budge more than 1/2 inch.
Remember, that brace is there for a reason. The engineers who designed these cars are much more intelligent than you or I. I'd reinstall it.
Old Jul 22, 2004 | 07:24 PM
HNDA ETR's Avatar
Still Here... IM me for more..
drove without mine for about 2 years.... then I decided to put it back on... Used large metal spacers and longer bolts....
Noticed NO difference with it back on...
Old Jul 23, 2004 | 07:05 PM
makavelisk's Avatar
When I replaced mine, I went to an experienced muffler shop and the guy there told me it need to be on and he just used two small metal washers under the bold and the pipe has never rubbed against it.
Old Jul 23, 2004 | 08:04 PM
Mick Max's Avatar
Wild at Hurt
I am sure it is there for one or more of 3 reasons.
Chassis stiffener
Passenger compartment integrity in the event of a side impact
Just a catch for the exhaust to avoid an accident should it fail as the car ages.
Guys on Car domain have spaced them down an inch or so like the others have said
It might not be a big deal to have it off but who knows?
Old Jul 24, 2004 | 08:51 AM
PearlWhtMaX2000's Avatar
i had some washers put on mine and its fine now.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
maxinout93
Oct 27, 2015 01:29 PM
FlaMark
25
Aug 28, 2015 10:15 AM
doobadoo
Aug 15, 2015 06:43 PM
