How Much Do You Trust Your Maxima?
Old Jul 21, 2004 | 09:34 AM
MrClemson8's Avatar
My "Check Engine" Light is on and I'm wondering what to do about it...
My car is running fine and I don't know how much faith I put in those "check engine" messages. I was thinking about taking it to a mechanic and get it disabled. If I take it into the dealer, they'll charge me an arm and a leg.
It's not the stupid BS like your gas cap not clicking three times...
So I don't want to damage the car, but at the same time I'm a little ticked off. I just had the 60,000 mile tune up in April and the car is running like a Swiss watch. (Except I had to get one of my ignition coils replaced in May per the TSB on it).
Any thoughts?
Old Jul 21, 2004 | 09:37 AM
MAXINXS's Avatar
Simple fix......... Take it to Autozone. They will pull the code from the cel for FREE!
Old Jul 21, 2004 | 09:38 AM
SoonerFan's Avatar
Cletus
its there for a reason..TO LET YOU KNOW THERE IS A PROBLEM!!!
go to autozone. they will pull all the codes for free. if you ignore one cheap problem you may cause a more expensive problem down the road
Old Jul 21, 2004 | 10:20 AM
jreddington3's Avatar
You can get the actual code out yourself. Here's the procedure:
Start with ignition off and foot off the pedal.
-Turn ignition on for 3 seconds.
-Then press pedal full and release 5 times within 5 seconds.
-Wait 7 seconds with your foot off the pedal.
-Then press pedal to the floor and hold for 10 seconds.
SES light will begin to blink. 1st set is slow, then a pause, then 2nd quicker set, then 3rd quicker set. This will be your 3 digit code. If more than one after a pause, the next codes will come up. By the way, zero is signaled by 10 flashes.
Factory manual will have lists of codes or I think they're kicking around the site here somewhere. I have the manual so haven't had to lool for it here.
By the way, to clear all codes, Once SES is showing the codes, press and hold pedal down for 10 seconds.
Old Jul 21, 2004 | 11:11 AM
MrClemson8's Avatar
Autozone... and the Dealer
Autozone pulled the code as a bad O2 sensor or too rich of a fuel mix.
The Dealer of course said that they would be the ones who needed to check it, for a cool $75 before they do anything. "A generic code reader will never be as good as ours," they said.
I'm a little ****ed because I just had the 02 sensor replaced in April for $400 installed.
So I guess I'll have to take it into CarMax?
Any suggestions? Is the dealer full of b.s.?
Old Jul 21, 2004 | 11:13 AM
MrClemson8's Avatar
The Generic Codes
The Generic Codes from Autozone were 138, 139, and/or 140.
Old Jul 21, 2004 | 11:53 AM
cjden20thAE's Avatar
It can be any one of four different o2 sensors the max has. Just replacing one doesnt cover you. If it IS the same one though, call the guy to replace it maybe he will help you out!
Old Jul 21, 2004 | 12:19 PM
JWrightMax's Avatar
Found myself heading out to my car to check this out when I realized I dont have my check engine light on. Thanks for the good info jreddington3.
Old Jul 21, 2004 | 12:34 PM
swiora's Avatar
Does anyone know where I can find the SES codes listed? Here or another site?
Old Jul 21, 2004 | 12:50 PM
† ErV †
I trust my car enough for it to take me anywhere and back. Oh my bad that was a post about a check engine light wasn't it? Maybe i should just ignore the thread titles from now on.
Old Jul 23, 2004 | 08:00 AM
zman187's Avatar
if thats the only problem you've had with ur 2k prepare for a lot more i have codes flying my direction every other week I'm sure I'll have something new next week
Old Jul 23, 2004 | 08:38 AM
MIKE2K2's Avatar
Custom User Title
Am i right to assume the procedure above will work on 5.5 gens as well?
Goffery2uned
Aug 21, 2015 09:50 PM
doobadoo
Aug 15, 2015 06:43 PM
julian888
Aug 6, 2015 04:39 AM
