What problems to look for when buying an 02-03 6spd???
Old Jul 27, 2004 | 05:43 AM
MaxedOutOfCash's Avatar
Pizda Boy
Once again, change of plans...
I am probably going to get an 02 or 03 6spd..
Is there anything I should look for in particular when looking at the cars?
Any known problems?
Thanks,
Sam
Old Jul 27, 2004 | 06:38 AM
Igor911's Avatar
Buy 1 with the LSD option if possible.
Old Jul 27, 2004 | 06:42 AM
2k2-blk-6spd's Avatar
Just make sure you drive it around first to check the 2nd-3rd and every other gear to 3rd switch, hopefully the synchros haven't gone bad and you'll get a good tranny. Good luck with your search! I should be starting my search in like 2 months and I'm also gonna be looking for a 2k2/2k3 6-speed, just like the one I had...
Old Jul 27, 2004 | 07:40 AM
aliti19's Avatar
Maxima addiction cured w/ the GS pill
3rd gear issues
Funny you mention this 3rd gear problem. I KNOW there is something wrong when i shift into 3rd gear. Anywhere from too much notchiness to not being able go get it in at all at times. I've taken it to the dealer 3 times for this issue and every time they tell me it's ok. I just think they don't want to pay up for a new tranny, or whatever else the problem is. I only have 10K miles on the car. Anyone know how to deal w/ these guys on the issue? It annoys the hell outta me.
Old Jul 27, 2004 | 11:08 AM
Yaco_Max's Avatar
there's nothing wrong with tats models as a matter of fact I was close to get a 2k2, but I couldn't because the problems with the head lights I like to park my car anywhere and sometimes I lke to drive to Jersey but to many members can tell you his personal history....
Old Jul 27, 2004 | 02:46 PM
Shoot only thing I could tell you to do would be to go to a different dealer because that's a synchro problem, the 3rd gear synchro went bad in mine twice, they replaced the transmission and on the 3rd transmission everything was finally how it should be. Keep bugging them, take a service manager out and let him drive and make him downshift into 3rd from any gear to see that it's not a "normal thing" because it doesn't grind any other gear. It took some convincing but my dealership finally came around...then again...but finally got it right the 3rd time.
Good luck with your car buying experience!
Old Jul 27, 2004 | 02:55 PM
MaximaPolak's Avatar
Wasn't that your plan like before you moved into your new appartment? What happened? Did you find one yet?
Old Jul 27, 2004 | 03:33 PM
imported_JIC_A33
02 new..20K no problems.
Old Jul 27, 2004 | 03:43 PM
ajahearn's Avatar
Make sure all recalls were done (transverse and gas pedal stop recalls come to mind but there are lists elsewhere on the board). It seems like early 02's (mine was one) had to have new clutch plates because of the "dying squirrel" syndrome. 03's seemed to have avoided this problem. MAF and ECM reprogram was another common 02 issue. Hope this helps.
Old Jul 30, 2004 | 09:29 AM
aliti19's Avatar
So i'm assuming that when the synchro goes bad the whole tranny has to be replaced?
Old Jul 30, 2004 | 09:44 AM
Not necessarily true. Nissan NA seems to prefer to just switch out the transmission with a new one instead of breaking it down and figuring out/correcting the problem. It's more "cost efficient" to simply install a new one and replace the old ones parts with new ones I guess.
Either way, if a synchro goes bad, as far as I know, you can simply replace that specific synchro and any other parts that it might have affected.
Correct me if I'm wrong please anybody, it'd be great to have some experienced people chime in here.
matts95max
Apr 23, 2025 10:44 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
markevans999
Sep 10, 2015 04:29 PM
nbstriker10
Sep 4, 2015 04:26 PM
