Boots for KYB GR-2 Struts/Shocks
Old Jul 30, 2004 | 06:49 AM
knapp9's Avatar
Where do you get them?
I ordered a set. Thought the boots came with. They didn't. The vendor I used and KYB web site doesn't list any. One Nissan dealer says oem equivalents are special order. Another says oem isn't even available.
Any help would be appreciated.
Old Jul 30, 2004 | 08:27 AM
[maxi-overdose]'s Avatar
cattmanperformance has boots for the AGX. I think they will fit onto the GR2.
Old Jul 30, 2004 | 09:15 AM
kirzan's Avatar
KYB actually does make them that fit the Max, but the rears are for a Mustang and the fronts are from another car -- can't remember which one. You can PM libradude97se for info. I think he called Tirerack and they were able to figure out which ones fit the Max. Good luck!
Old Jul 31, 2004 | 05:28 PM
knapp9's Avatar
Thanks for the help
The AGX boots were a very good buy, but they just looked different than what I have on my '01. libradude97se's Max looked to be a '99 so I didn't bother him either.
I ended up ordering the rear boots from Courtesy Nissan. They sounded like they knew their parts & were 50% less expensive than my local jerk dealer. I experimented and ordered the front "bellows" (as I learned these parts are often called) from RockAuto.com. They showed A LOT of Maxima parts on their web site and were 40% cheaper than Courtesy to boot. 1st time I ever dealt with either of these two guys...shipments should arrive at the house late next week...got my fingers crossed.
Old Jul 31, 2004 | 05:53 PM
carabuser's Avatar
keep us posted. I think I'm gonna face the same problem
Old Jul 31, 2004 | 08:15 PM
glemax01's Avatar
sounds good...very shameless plug/informative
Old Aug 18, 2004 | 04:41 PM
knapp9's Avatar
Here is how it all turned out...
The rear dust boots from Courtesy worked perfectly. The front dust boots from RockAuto did not fit at all and I had to return them. The installer just reused the old front boots.
Next time I'll just order everything from Courstey and not mess with looking for the lowest cost.
Old Aug 18, 2004 | 04:55 PM
kirzan's Avatar
Dude, I wish you had messenged libradude97SE -- hence the name he has a '97. He's a very cool guy, he would have hooked you up on the info. We have the exact same suspension setup -- Maxspeed on KYB GR2s and his ride is MUCH better than mine. He got the KYB bump stops/shock boots and it's so much better. I crash into my bump stops all the time and his ride is pretty nice. I'm going to Illuminas or GRXs pretty soon. Hope you're enjoying the new setup, tho.
knight_yyz
Nov 1, 2015 01:34 PM
maxima-junky
Oct 7, 2015 06:13 PM
dvcamp
Sep 18, 2015 10:17 AM
