weird problem with blinker
Old Jul 30, 2004 | 08:10 PM
mjg's Avatar
mjg
Hey.
I went to put the new blinkers in, and yet the side that as out, still would not work.
Has anyone have a problem like this? I'm really hoping to avoid going to nissan before i fix 'other' problems (long story) so i wish i could resolve this problem on my own.
Help!
Old Jul 30, 2004 | 10:06 PM
Max_5gen's Avatar
Originally Posted by mjg
Hey.
Help!
I understand that you meant "turn signals". If that is the case then the same wire feeds three places: front turn signal lamp, rear combination lamp and dashboard indicator. Are all of them not blinking? I'd swap bulbs from side to side just to check that it's not them. OTOH if all three are out then it could be combination switch (the one on the steering wheel) the rest are just wires. Both sides share the same circuit up to the battery starting from combination switch. There's simple way to check - if you turn on you "hazard light" switch and both sides start blinking then it's the combination switch if one side is still out - that's wires. "Hazard light" switch feeds turn signals in parallel with combination switch.
Old Jul 30, 2004 | 10:12 PM
scopium
yea i have the same problem
i've checked all my lights and they work but my driver side blinker dont work.. swaped it with new bulb and still doesnt work..
all the other lights work.
could it be the socket?
Old Jul 30, 2004 | 10:13 PM
mjg's Avatar
mjg
yes i meant turn signals sorry. I will try that. Yet all those other lights seem to e the problem.
Thanks, good info.
Old Jul 30, 2004 | 10:30 PM
mjg's Avatar
mjg
i checked
it must be the wires then, because the hazards do the same thing. Nothing else is effected.
Real weird. Im gonna try tommorow just swapping the bulbs around. This really sucks for me, because i won't go to the dealer until i finally relocate my 02 sensors from the header thing. That way i dont pull in with my SES light on and have them annoy me bout that or try to blame me .
ALso, u think if i go with the piaa bulbs they will try to blame that? I lost one of the bulbs, this sux.
Old Jul 30, 2004 | 10:46 PM
Max_5gen's Avatar
Almost any bulb on the car can be checked by connecting between + battery and the body of the car - the're all 12V. If your rear driver side turn signal works then it is the wire/connector/ground from the combination switch to the front bulb. I'd start from around the bulb - it is more likely to have bad contact somewhere in a connector/socket/ground.
AaronL
Nov 15, 2020 11:52 AM
05RLS2
Sep 27, 2015 09:24 PM
yamehoo
Sep 24, 2015 10:21 AM
bennuss
Sep 11, 2015 05:55 AM
