stock pads with crossdrilled rotors??
Old Aug 3, 2004 | 06:13 AM
ornery1's Avatar
will this be ok???any downfalls to doing this??? i want better rotors but i dont want squeeky brakes
Old Aug 3, 2004 | 09:52 AM
gameover03's Avatar
Bump.........
Old Aug 3, 2004 | 01:48 PM
ornery1's Avatar
what does bump mean??????
Old Aug 3, 2004 | 03:28 PM
MiniRX7's Avatar
Um.. no, your probably going to get a lot of dust because the OEM pads are too soft!
Old Aug 3, 2004 | 03:33 PM
Jeff92se's Avatar
I'm needing a caw
The brakes will make noises when you slow down
Pad wear might accelerate
Once you put any grooves in the rotors you can't turn them. You can't turn down drilled rotors
Old Aug 3, 2004 | 03:44 PM
2k2kev's Avatar
It's chrome alright...
cross-drilled rotors are not necessarily better rotors...there are plenty of blanks that are just as good, if not better than cross-drilled or slotted.
IMO, cross-drilled and slotted are for show, so get them if you want them for show but NOT if the ONLY reason is for better stopping under normal driving (meaning daily driving and not auto-x)
Old Aug 3, 2004 | 04:12 PM
Triple8Sol's Avatar
I miss the .org!
Sounds like his question isn't about whether to get rotors or not, but whether to use stock or aftermarket pads. I'm running stock pads on my rear rotors right now, because there looks like another year of life on them. At that point I'll replace them...
Old Aug 3, 2004 | 04:37 PM
tdogg169's Avatar
I am running stock pads with my crossdrilled rotors. They do cause more dust on rims but no other problems.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
jaydot901
Sep 29, 2015 01:18 PM
Socalstillen
Sep 26, 2015 12:01 PM
