Pulled a SES code, what should I do?
Old Aug 23, 2004 | 06:15 PM
shaz's Avatar
So I put an frankencar intake in my 02 and I've gone about 400 miles. Everything is fine, but then my SES light came on. So I pulled the code: P0037 - Heated Oxygen Sensor 2 Heater Low Voltage (Bank 1). I figured it was the MAF but amazingly its an O2 sensor. Does this mean my sensor is bad and I should replace it? I reset the ECU, should I give it some time and see if it comes back on? Thanks
shaz
Old Sep 1, 2004 | 09:22 AM
shaz's Avatar
Ok, the light came on again. I guess I'll go ahead and replace that sensor. Where's the cheapest place to pick one up? Thanks
shaz
Old Sep 1, 2004 | 12:37 PM
edgenuts's Avatar
how did you reset the ECU? unplug the battery?
Old Sep 1, 2004 | 12:40 PM
Jeff92se's Avatar
I'm needing a caw
Clean the maf?
Old Sep 1, 2004 | 01:00 PM
shaz's Avatar
reset with the whole pedal, key turn scenario etc.
Havent tried cleaning the MAF, to scared it'll break. How do you clean it? And why would the MAF throw a 02 sensor code? thanks
shaz
Old Sep 1, 2004 | 01:05 PM
edgenuts's Avatar
shaz,
cleaning the MAF is easy. I did it last night. I used a little isoprohply alcohol and a q-tip and as you know be careful.
I tried messing around with the pedal, key turn stuff last night but I didn't have an analog clock, I just kept counting "Misissippi"s. =] I need to find me a good analog clock so that I can try this for real.
Old Sep 1, 2004 | 01:08 PM
edgenuts's Avatar
One thing I neglected to mention, once you unplug the MAF and remove the two tourque screws, it is a pain in the **** to get out. I had to use a screw driver to "gently" pry it up from both sides. It helps if once the screws are out, you turn it 90 degrees so that it is perpandicular to the screw holes. I hope that makes sense.
Old Sep 1, 2004 | 01:11 PM
shaz's Avatar
Originally Posted by edgenuts
shaz,
Its a pain to get right... even with a stop watch it took me like 8 tries. I cant figure out what the trick is to get it every time. Anyways, maybe I'll try cleaning it. thanks for the suggestion
Old Sep 1, 2004 | 01:16 PM
edgenuts's Avatar
yeah it sounds like a major pain but it works and that's fantastic! this is the first confirmation i have of this technique actually working.
Mar 12, 2020 12:06 AM
Steven Orozco
Sep 12, 2015 10:41 PM
