Plug & Play Plan.
Old Aug 24, 2004 | 07:22 AM
SKYRockerr's Avatar
Plug & Play Plan.
Okay, i am looking for wiring harness male and female that connect for 9007 high beams for stock 2k2 maxima's.
And i am looking for male and female wiring harness that connect to stock 2k1 for both low and high beams
I wanted to connect my low beam 2k2 wiring to stock 2k1 harness minus the high beam connection .
whats the point of this.
Basicly rewire my stock 2k2 hid wiring harness in to 2k1 low beam harness so i can plug and play my 2k2 hid at home. plug and play 2k1 lights in my maxima when i travel in to theft prone area's .
Regardless both set of lights will keep stock 9007 high beam connector . which would mean rewiring stock 2k1 set of lights high beam harness. which is really easy.
Right now i have hard wired set of 2k2 projector headlights. I want to remove those.
Since both high and low beam use 12V, its really the negative that gets cut off or cutt on when you switch from high and low, and during low beam the high ground is off, but during high beams both you grounds are on.
I can rewire 2k1 high beams to 9007 harnesss , rewire 2k2 hid harness to 2k1 low beam harness and we have it plug and play with minor tweaking.
As far as clerance light / angel halo rings for projectors those if i can find a tiny bit harness for my projectors / 2k2 hid's thats fine. turn signals are the same wither in 2k1 or 2k2 .
It sounds complicated and maybe flat out confusing but its very easy and with the right harness some soder and some good connectors ( radio shack? ) and solid black tape a very easy fix.
When travelling over the weekend to hid theft area's plug and play 2k1 lights or my projectors ( which can just as easily be stolen) when @ home install 2k2 hid's which i miss not having in the car.
what do you think?
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
Andy29
Sep 29, 2015 05:32 AM
