Bump stop replacement cost? Roughly?
Old Sep 13, 2004 | 04:00 PM
NYPD-Arnold's Avatar
Z
Well, it appears that the clunk/creaking/croaking noise that's coming from the front of my suspension is because worn bump stops; apparently the struts are rubbing against each other or some such. How much does it cost to get a new set installed? I'm not looking for a concrete number, just a ballpark figure.
Help.
Old Sep 13, 2004 | 04:04 PM
redstradic's Avatar
i would go ahead and just get the dustboots as well. the bumpstop is up inside the dustboot. not sure if you could buy them separately or not. however, i ordered mine from Dave Burnette, cost me around $80 for all four.
Old Sep 13, 2004 | 04:21 PM
Z
I guess I wasn't too clear...but I need to know how much it'd cost to install them.
Old Sep 13, 2004 | 05:09 PM
Zero Deuce SE's Avatar
Might as well get new struts since they have to be disassembled to replace the bump stops anyway. It will likely cost close to the same labor as strut replacement.
Old Sep 13, 2004 | 05:10 PM
Number 9 is the bumpstop with the dust boot.
Old Sep 13, 2004 | 05:27 PM
Z
WTF. New struts? You've got to be kidding. I just had these blues installed less than a week ago!
Old Sep 13, 2004 | 05:47 PM
I could not tell that by your original post. Excuse me for thinking too far outside the box. The struts still need to be disassembled to install bump stops though.
Old Sep 13, 2004 | 05:49 PM
Z
Man, I hope I can get this done and not have my wallet suffer too much.
Old Sep 13, 2004 | 05:51 PM
See if you can get an org member in your area to help you out.
Old Sep 13, 2004 | 06:07 PM
irish44j's Avatar
retired moderator
that doesn't sound like its the bumpstops - I just did my springs and struts last week and can't see how the bumpstops could cause that problem. It sounds more like the top hat (part 11-17 in the drawing) is not correctly aligned....that or something is loose. the bumpstops don't even come into play unless you're bottoming them out.
But expect to pay several hundred $$ to change them, if you're convinced that's the problem.....to get to them you have to take apart the entire spring/strut assembly....so it would cost about the same as replacing the springs/struts
also make sure the strut bearing (13) is not bad...if they crack you can hear some noise.....
also!! - did they put the spring isolator back on the springs (the rubber/plastic piece that wraps around the bottom of the spring)?? If not, then you will definitely get noise...
you can see it in the pic below:
Did you get these installed by a shop? If so, suggest you go back and tell them they did something wrong.....I did my Maxspeeds w/Illuminas by myself and haven't had this problem.
Old Sep 13, 2004 | 06:29 PM
Z
Irish: What drawing? You've got me curious...I want to make sure that when I'm going back into the shop they fix the problem. I'm going to write down a list of possible problems and tell them tomorrow.
Keep helping me out guys.
Old Sep 13, 2004 | 06:33 PM
irish44j's Avatar
retired moderator
the drawing posted above (the spring/strut assembly diagram) by charliekilo....
seriously though, I see no way it couldbe the dustboot/bumpstops making this noise.
Old Sep 13, 2004 | 06:36 PM
Z
Heh, didn't see the pic up there for some reason. Totally missed it. I'm gonna' print it out and point it out to them.
95Maxi
35
Sep 2, 2015 10:37 AM
FlaMark
25
Aug 28, 2015 10:15 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
scarletsosa
Aug 17, 2015 09:09 PM
kirkhilles
Aug 8, 2015 10:53 AM
