Do Hubcentric Spacers come w/ diff. outer bore diameter?
Old Sep 25, 2004 | 02:17 PM
WildmanAL's Avatar
Hey guys I need some help. I'm getting 300zx calipers and need another .5" for them to fit under my 19".
Right now I have hubcentric rings with my aftermarket wheels. When I ordered these they needed the inner bore diameter (66.1) and my outer bore diameter (73.1). I had to call the place of where I got the rims for the outer diameter because the guys at Tire Direct don't carry those wheels and didn't know the diameter. If I get hubcentric spacers do they come with a 73.1 outer bore diameter?
Old Sep 25, 2004 | 03:01 PM
WildmanAL's Avatar
Yeah I know this is a pretty stupid question, but somebody has to know. I'm not sure if rims have different bore sizes, but I know there are different sized hubcentric rings that have different outer bores for your car.
Old Sep 25, 2004 | 04:25 PM
WildmanAL's Avatar
Okay I don't know if this thread is confusing or what, so how abou this.
I'm asking are the rings on the spacers hubcentric or are they just sleeves for my hubcentrirc rings to slide over.
Old Sep 25, 2004 | 05:21 PM
MIXXMAX's Avatar
Yes, you must know the hub size of your aftermarket wheel. This will be the outer dimension of the ring, where your inner size is your factory hub which is 66.1 for us Maxima owners. If you have the wheel, all you do is get an analog or digital caliper and measeure the hub size inside the wheel. This will give you the dimension you will need in getting the proper hub rings. But, reading your post it seems confusing because you said you bought different calipers and wondering about the fit/clearance of the wheels. By any chance, are you looking for SPACERS, instead of HUB RINGS to clear the calipers after mounting the wheels? Spacers and hub rings are two different things serving different purposes.
Old Sep 25, 2004 | 05:26 PM
MyownNismo's Avatar
Future Camaro SS owner
www.justforwheels.com The can match with wheel company. Yes it's 66.1
Old Sep 25, 2004 | 06:05 PM
ZIPPIN's Avatar
Mauja He Mauja
do we need to worry about this when getting the h&r spacers??
Old Sep 25, 2004 | 06:19 PM
MyownNismo's Avatar
the hub should be long enough where the wheel will still be on hub.
Old Sep 25, 2004 | 06:26 PM
WildmanAL's Avatar
Yeah I'm talking about hubcentric spacers and not just hubcentric rings. I'm wondering if you have to order the spacers like you would with the rings.
You know when you order hubcentric rings you provide them with the make and model of your car and brand of rims. With that info they send you the proper rings with the correct outer and inner diameters....... Now with the hubcentric spacers so I have to do the same thing?
I found a set of spacers online. The seller just states that they fit 114.3 bolt patterns and that's about it. I'm just trying to figure out if the outer diameter will be correct.
Old Sep 25, 2004 | 08:52 PM
ZIPPIN's Avatar
Mauja He Mauja
I found a set of spacers online. The seller just states that they fit 114.5 bolt patterns and that's about it. I'm just trying to figure out if the outer diameter will be correct.
ask the seller if the outside center, sticks out. you can ask for a pic from the seller and post here. we will tell you if it is hub-centric...
Old Sep 25, 2004 | 09:07 PM
WildmanAL's Avatar
I know what hubcentric spacers look like. I'm asking if outer bore diameters are different from set to set to fit certain wheels.
This thread is way too confussing so here is my question simplified.
ARE ALL OUTER BORE DIAMETERS 73.1 FOR ALL AFTERMARKET WHEELS OUT THERE?
I thought they were all different because when I ordered my hubcentric rings they needed to know what brand of wheels I had so they could send me the right outer bore diameter.
Old Sep 26, 2004 | 12:15 AM
MyownNismo's Avatar
If you got or getting spacers get the H&R spacers cause they're made for the maxima which would make them the 66.1. That's why they are hubcentric.
Old Sep 26, 2004 | 04:44 PM
MIXXMAX's Avatar
To answer your question, NO. All outerbore diameters of aftermarket wheels are not 73.1. That is why most companies want to know what BRAND of wheels you have. With this information, they will no exactly what the dimensions are for the outbore because of the manufactuer who made the wheels.
Old Sep 26, 2004 | 05:00 PM
WildmanAL's Avatar
Well then that means that hubcentric spacers are different. See I don't see how when you order H&R spacers they don't ask you for your brand of wheel so they can send you the hubcentric spacers with the right outer bore diamter.
Old Sep 26, 2004 | 05:55 PM
MyownNismo's Avatar
H&R spacers for maxima. notice the 66.2mm. All hub centric rings for wheels do it keep the wheel on more balanced on hub instead of just the studs and lugs. your trying to clear 300zx calipers all you will need is these spacers. The same spacers I need to clear the AP/stillen BBK.
knight_yyz
Nov 1, 2015 01:34 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
londonflu
Sep 19, 2015 02:33 PM
Bonka
Sep 14, 2015 11:18 PM
