removing the bezel around the stereo unit
top vents just pop out if you pull on the vents themselfs. Lower shifter cover has one bolt through the ashtray and pops out. You can then get access to the radio or HVAC bolts that hold them to the dash.
there's a screw inside the ashtray behind the tray/ashtray inside a hole. phillips, unscrew that and pull the bezel up around the shifter(manuals are much easier) with something softer than a flathead... and then straight out
what he said....
but there is also a website that has detailed instructions. Find them at:
http://www.carstereohelp.com/stereor...NisMax3Str.htm
RealityCheck
Oct 2, 2015 06:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
