Alarm randomly goes off...
Originally Posted by SE01
My panic alarm randomly has been going off today for about 30 seconds at a time. It does it out of no where at random times. Anyone know what the problem is?
Originally Posted by Gennady7
i think the maximas have a sensor and that sensor is giving off false readings, like a car passing by or something like that.
Originally Posted by kieranlavin
How is your battery? With my 200SX, I left my lights on once and the battery went dead. The second the battery saw voltage again, the alarm started going off! I had to pull those fuses and charge the battery and then put them back in and disarm the alarm. Not quite similar but maybe an idea? ... bad battery giving intermittant power?
Make sure your dome light, vanity light, etc. aren't left on. Make sure all doors, hood, and trunk are closed.
Disarmed phase, turn ignition switch from ON to OFF and remove key from ignition. "SECURITY" led will blink every 2.6seconds.
Pre-armed phase, lock doors using remote. "SECURITY" led will stay on for 30seconds.
Armed phase, "SECURITY" led will blink every 2.6seconds.
Does this all happen? If not, which fails?
Everything happens in the right order like you said Icy, but my car can just be sitting in the parking lot by my apartment and i hear the alarm go off. maybe those squirrels storing their food in my engine bay...ha
I *KNEW* this sounded familiar:
http://maxima.theowensfamily.com/tsb/NTB01-009.pdf
Good luck~!
Good luck~!
zzznightmarezz
Sep 21, 2015 06:32 PM
lrb6805
Sep 17, 2015 04:49 PM
