2k3 Warped Rotor Question
Old Sep 28, 2004 | 08:36 AM
Dohcser's Avatar
Sorry to bring this back to life, but was there a recall or TSB for front rotors being warped on the Max's?
Old Sep 28, 2004 | 08:43 PM
GimmeTorq's Avatar
No. There is only a brake "judder" TSB but only applies to 2000-2001, I believe. Check the TSB stickie in this forum.
Old Sep 28, 2004 | 08:50 PM
SEmy2K2go's Avatar
Go BUCKS!!!
You should be able to have Nissan replace them under your warranty if you're under 36k miles.
Old Sep 28, 2004 | 09:21 PM
GimmeTorq's Avatar
Depends on the dealer. My dealer just kept resurfacing them...
Old Sep 29, 2004 | 02:41 AM
wild willy's Avatar
Legally..they can only cut so much off...Mine got so thin..The CHEAP fockers had to replace them
Old Sep 29, 2004 | 04:59 AM
Qmax03
i got 13k on my 03 max will the dealer replace mine i see crackes in the rotors and they SUCK A$$
Old Sep 29, 2004 | 06:38 AM
boondoxmax's Avatar
i am going to the dealer on oct.8th for this problem. they turned them before and it took care of the problem for about 4000 miles now they are warped again. i have 34000 now so i want them to replace the rotors not turn them. so far quirk nissan has been pretty good
Old Sep 29, 2004 | 08:51 AM
wild willy's Avatar
You Know what they say "Want in one hand, Shiat in the other"
I wanted new ones too..they cut them till they could not be cut anymore by law
Old Sep 29, 2004 | 12:49 PM
03maximan's Avatar
I've got 30K on mine and the brakes are smooth as day 1, should get at least 40K out of the originals.
Old Sep 30, 2004 | 09:00 PM
GimmeTorq's Avatar
Rotors have a minimum thickness... For the Max front rotors is 22mm. After cutting them twice, they a pretty much at about that limit and cannot be cut again... Of course, dealers know that. When I went for a third time complaining about vibrations when braking, hoping they would replace them (they had cut them twice already abd the car was still under warranty), tech denied it was the rotors... and suggested tire rotation/balancing and alignment.
Old Oct 7, 2004 | 08:08 AM
SpottyJ's Avatar
Anyone have luck with dealers repairing front brake shuddering on 2002 Maxima's? I went to a local shop and they stated I need new pads and rotors ($400). But, they said there is a TSB out for my car and that I should bring to dealer. The TSB # the local shop gave me was NTB-00-033A. Searching that TSB number I can't find anything.
I have 25,000 miles on my 2002 SE.
Your input on what dealers have done for you, and if you have seen this TSB is appreciated.
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Socalstillen
Sep 26, 2015 12:01 PM
