Upgrade Reverse Lights??
Old Apr 10, 2001 | 05:54 PM
killrwheels's Avatar
I am looking for the actual size of the bulb needed to replace rear back-up lights........It appears to be a bulb larger than a wedge but exact size is not known....
Someone out their had a Sterling Mist with Blue backups at the Broward Mall (Fl) last weekend....nice !!!
Old Apr 10, 2001 | 07:00 PM
DKNYchinito
there's a new sticky thread above with all bulb info.
Old Apr 10, 2001 | 07:01 PM
DKNYchinito
just checked... its a "super wedge bulb".
Old Apr 10, 2001 | 07:06 PM
I looked at the sticky also......but no number listed for this piece. It appears it may be a w2 but do not want to order until certain as PIAA's are expensive to just throw away.....anyone got the bulb number???
Old Apr 10, 2001 | 08:22 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Stock is a KOITO 912 which is 12V and 13watt bulb.
I replaced mine with a Sylvania 921LL 15watts from Autozone. It's white and brighter than stock to compensate for my tint at night.
Old Apr 10, 2001 | 09:08 PM
yongjun's Avatar
You can use a regular wedge bulb too
but if you are looking for it.
Just look for a wedge bulb with a fatter bulb part
i have a pic here
Old Apr 11, 2001 | 01:02 AM
areX's Avatar
careful...
careful about getting the right bulb, tho. i had a friend of mine get me one at Autodynamic's store and he came back with a bulb the same size as the brake lights... TOO FAT. it's the one right in between the 194 small wedgies and the big break fatties. they should be numbered as "921" according to Autooptiks.
search around. if you search, you will find.
Old Aug 30, 2020 | 02:10 PM
Thrillho's Avatar
Originally Posted by Melikos
Yes, the backups are important, but even this measure does not always help.
yo my dude, I don't know how it's on here but on most forums it's frowned upon to bump a 10+ year old thread.
Old Aug 30, 2020 | 04:12 PM
Donkeypunch's Avatar
frowns be damned then.
threads are forever if it helps someone searching for it later on then why not.
Amazon Amazon
i'm using this bulb on the passenger side hit helps a TON when parking and you have tinted windows.
those led ones aren't even close to being as bright.
Shannon and Ian
May 18, 2016 05:03 PM
Maxima-Ness
31
Apr 12, 2005 07:25 PM
xsp00kyx
Apr 29, 2002 11:44 AM
PejMax97SE
Apr 15, 2002 10:03 AM
block
Nov 5, 2000 09:45 PM
