Need advanced help for interior lights mod - not working!
Old Oct 1, 2004 | 03:05 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I am going for the interior light swap-out to blue on my Max. I started with the driver-side door today. I removed all the old leds, took the old solder off, and was left with four small metals plates on each of the leds. I then soldered the + end of the led to the two + plates I just mentioned, then the negative. I put it all together, plugged it in, and it did not light! =(
Anyone have any thoughts as to why this may have happened?
Are the lights in series and maybe I have one soldered wrong? The other lights are lighting fine.
Old Oct 1, 2004 | 03:29 PM
Pri63's Avatar
I followed these direction for my 00 SE...worked perfectly
http://www.alexhsu.com/maxima/ledinstall/
Old Oct 1, 2004 | 05:14 PM
MIXXMAX's Avatar
Yeah, when soldering you must cross the old led contacts in order for them to work. Make sure the negative side is soldered on the "[" marked on the circuit board. Don't let any of the solder touch the other contact points of the old surface led or the LED will not light up. The old one will continuously light up. Once the new LED is wired/soldered right, it will cancel the old LED, and the old LED will go out.
Old Oct 2, 2004 | 01:07 AM
DAMMIT
I soldered both contact points for the LEDs! Well, it shouldn't be too hard to fix now that I know what is going on. Thanks for your help, guys...back to the workbench!
Old Oct 2, 2004 | 03:17 AM
One down...four to go
Ben2003GLE
31
Jul 17, 2016 08:13 AM
Slamrod
Apr 10, 2016 05:24 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
