question for ones with RSB's...
Old Apr 11, 2001 | 06:40 AM
silvermaxd's Avatar
Just installed mine last....damn thing fit like a glove and love the anodized brackets..anyway do you fellows jack your cars rear end up by the RSB now or what being it's right under the rear beam?
Old Apr 11, 2001 | 07:48 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Oh no! Don't jack the car up from the RSB. The Stillen bar shouldn't be blocking your rear beam. IIRC, there should still be a few inches of clearance for a jack.
Old Apr 11, 2001 | 07:53 AM
mdeal's Avatar
The Stillen instructions recommend placing the RSB directly beneath the rear beam. Therefore, you shouldn't be able to jack it up by the rear beam.
I jack using that center piece thing, or do one side at a time.
I once jacked it using the beam (pre-RSB) but it flexed too much for my liking.
Old Apr 11, 2001 | 08:04 AM
silvermaxd's Avatar
hmmm that center thingy did'nt look stout enough to jack up the car. I jacked it up by RSB on the ends near the brackets and it seemed ok. I had no choice seen my jack stands were at the jack points in front of the wheels.
Old Apr 11, 2001 | 08:07 AM
Y2KevSE's Avatar
Hmmm.... Either I didn't see that in the instructions, or I didn't follow the instructions.
Old Apr 11, 2001 | 08:17 AM
Y2KevSE's Avatar
From what I can see, Paul2kGXE's bar isn't right underneath his beam either.
Old Apr 11, 2001 | 08:29 AM
bcannon's Avatar
I remember reading that the farther forward you mount the RSB, the more rigid the car will be and vice versa for mounting in back farther. I have heard you are likely to spin out in cornering too hard if your rsb is mounted to far up, making the car too rigid and making it loose it's grip.
Does anyone else remember reading that on a thread?
Old Apr 11, 2001 | 09:20 AM
punkdork's Avatar
I just remember that you could adjust it... unlike the Addco one. Now I gotta get a Stillen RSB.
Old Apr 11, 2001 | 10:08 AM
mdeal's Avatar
For clarification, I jacked the car up once using that center thingy. I believe this was the time in which I installed the RSB. It doesn't look like it should be the jack point, admittingly. I typically jack up either one side or the other.
I thought Paul's pics showed the bar directly beneath the beam. Maybe I just think this because of the recommended instructions or from some rogue thought in my pea brain.
Whatever the case may be, the rear beam really gets some flex to it if you stick the jack under it. I was afraid I was going to permanently damage something.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
