View Poll Results: Buy a K&N Filter
Yes
90
60.40%
Stick with stock paper
40
26.85%
Get other..
19
12.75%
Voters: 149. You may not vote on this poll
K&N Filter
Old Oct 4, 2004 | 12:29 PM
S00NR1's Avatar
OU > *
K&N Filter
I am trying to decide whether just to stick with the stock paper filter or go ahead and spend the 50 bucks to get the K&N for my AE. Also, if you chose "get other", what other type of drop in are you referring to? After reading what I could find on this board, I don't have enough information to make a decision. What are your thoughts?
Old Oct 4, 2004 | 12:35 PM
Puppetmaster's Avatar
I had a K&N drop-in for almost 30k miles and never had a problem with it. There aren't any performance gains though, if that's something you're looking for. I felt there was slightly improved throttle response, but that could be my imagination. But anyways, if ya do get it, just be sure to not over oil it when you clean it, since apparently that's what's causing all the MAF problems. This applies to the panel filter for the stock airbox, and to the cone filter that K&N makes for intakes.
Btw, the only reason I'm not using it now is because the techs at the Nissan dealership I went to either were dumb enough to throw it out (despite the big sticker on it saying NON-DISPOSAL FILTER) or they just stole it.... I only found out much later when I opened my airbox and found a paper filter in there....
I have a Berk intake now with K&N cone filter and that's been good to me for the past 250 miles thus far....
Old Oct 4, 2004 | 12:39 PM
Anuj's Avatar
i don't justify spending $50 on an air filter like that. I would stick with the OEM Nissan one unless you actually get an aftermarket intake.
Old Oct 4, 2004 | 12:55 PM
2002 Maxima SE's Avatar
$50...wow, thats a lot. I got mine for $35.
Do you mean that you use the same $12 filter from Nissan for the life of the car?
Old Oct 4, 2004 | 12:58 PM
Anuj's Avatar
no, replace it whenever it needs to be (i clean it every couple months)
edit:
the starter of this thread said $50, that is why I wouldn't go with it
$35 doesn't seem so bad but why not just go OEM? Does K&N make a remarkable difference in filtering capabilities?
Old Oct 4, 2004 | 05:18 PM
bigdo26's Avatar
but you can clean the K&N. it does breath better than a stock one, if ya do the GAB with it, well seems to work pretty well. Altho I did blow my MAF at 28k, 27k of which I had the K&N in... dunno tho, these MAF's crap out all the time
Old Oct 4, 2004 | 06:17 PM
GreekMaxima's Avatar
yesterday i went to the meet in RI and a guy with drop in k&N filter... he gave me the paper of the dyno and... yes 4 extra HP with just drop in filter
Old Oct 4, 2004 | 06:31 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
alot of people have teir comments on the filter. I experienced on my last car that it toped out at 125mph, I put the K&N and it went over to 135mph where it hit governor i think. and it gave it a loud grunt sound when eccelerator pressed. my opinion get it for a starter "not really" mod.
Old Oct 4, 2004 | 07:01 PM
S00NR1's Avatar
OU > *
Where were you able to find one for 35?
Old Oct 4, 2004 | 07:32 PM
"PoW"'s Avatar
go to http://www.ajusa.com/cgi-bin/store/start?r=store& got mine there for cheap and with free shipping.
so far i have had my k&n in for a few months. gas milage has improved and i also feel a slight diference in the throttle response at low rpm's.
Old Oct 4, 2004 | 07:43 PM
Trance Artur's Avatar
Anyone know the K&N part number for the 3" filter that goes on the frankencar mid-pipe?
Old Oct 4, 2004 | 08:13 PM
edit:
The K&N also lasts for 100K miles with regular cleaning and oiling, so that def beats replacing a $12 filter every several thousand miles (I'm not sure how many, but its not a lot).... someone correct me if I'm wrong....
Old Oct 5, 2004 | 06:17 AM
Anuj's Avatar
hmm you guys may be changing my mind on this
never really looked into changing the filter to an aftermarket one
Old Oct 5, 2004 | 06:26 AM
Or you could just shell out a few extra bucks and get an intake which will give you a nice growl andd some gains. Most will have a nice big cone filter which will last you a while too...
The reason why I ended up going with a Berk intake is cuz it was only $10 more than a K&N drop-in at the time (although I added a midpipe to it for more $$$). If you're interested check with cobymoby or just go here http://forums.maxima.org/showthread.php?t=331665.
Old Oct 5, 2004 | 08:03 AM
edit:
I did an UOA on my car at around 30k with 20k on the filter. The UOA showed a lower than normal amount of Si in the oil. The K&N filters better as it gets dirty but should be cleaned every 50k. So, for the price of $35 to $50 you have a filter for the life of your car. For those of use who keep a car 10 years, this is good (regular filter is around $12 every year...so roughly $120 in the end). People who only keep a car 3 years may not agree.
Old Oct 5, 2004 | 08:08 AM
There were a few places online that would let you order one for $35 to $40 (with free shipping). It was 3 years ago so I'm not sure where the site is.
Old Oct 5, 2004 | 09:17 AM
S00NR1's Avatar
OU > *
It's funny that you should mention this. I saw that GD last night and pretty much made the decision that I would purchase the K&N full kit. I can't justify spending an extra sixty bucks for the Apexi filter, the K&N should be just fine.
Old Oct 5, 2004 | 12:05 PM
I agree... but just watch out when you have to clean and re-oil it. Excess oil seems to be one of the reasons so many people are blowing their MAFs...
Btw, I love it... I think it sounds awesome...
Old Oct 5, 2004 | 12:08 PM
schmatt's Avatar
Stick with stock. There are no performance gains. And the K&N will not filter as well as the stock paper. It's a waste of money.
Old Oct 5, 2004 | 04:21 PM
ICELANDIC MAX's Avatar
no problem so far with k&n. i'm considering an intake though
Old Oct 5, 2004 | 05:20 PM
Chaser's Avatar
Get it!!!!
It's a simple replacement filter that improves your gas mileage fuel economy a little but dyno improvements and reduces the cost of paper filter replacements every 3000-4000 mile or whatever!!! Just buy it I get one for ever car I purchase. My expo has one my Slowyota had one and my max had one until I bought my Injen intake. Just get it. Go to your local auto parts store and you can get it between 35 and 45 dollars..
Old Oct 6, 2004 | 08:34 PM
schmatt's Avatar
Just read this article on air filters. This should help you decide which way you want to go.
http://www.bobistheoilguy.com/airfilter/airtest1.htm
Old Oct 6, 2004 | 11:57 PM
S00NR1's Avatar
OU > *
Thanks for linking that article Schmatt. Unfortunately after reading the discussion on the BOTG msg board analyzing it, I think it would be very difficult to make any conclusion from those tests. First of all, the tests were done on a 1992 Miata, and I am sure it is a total different system when compared to the 2001 Maxima. After seeing the poll results from this board, I feel comfortable in purchasing the K&N intake from Berk and shouldn't have any problems with it.
Old Oct 7, 2004 | 10:55 AM
schmatt's Avatar
Well, that's your choice. But many people on BOTG forum also feel negatively about the K&N. It doesn't really matter what car you are looking at. There is a air intake with a filter in the way. How well this filter works will determine how clean your engine stays. I personally ruined my stock MAF with it. It was overoiled from the factory. I have since switched back after seeing all the negative info on it. I have more piece of mind using the stock paper filter.
Old Oct 7, 2004 | 02:49 PM
ATX_Maxima_02's Avatar
I have the FRAM Air Hog....seems to be as good as K&N. Had a K&N filter in every car or truck i have owned.
Old Oct 19, 2004 | 03:43 PM
MY2000MAX's Avatar
I have a Fram. Dont know how it compares to a k&N but its way better than stock.
Old Oct 19, 2004 | 06:55 PM
mikelly's Avatar
Soonr1,
As you can see there are various opinions on K&N filter. Personally I have K&N panel
filter on all my vehicles. I have not blown any MAF on any of my vehicles. Out of 5
K&N filter I bought, only one was over oiled. I cleaned it immediately before installing
it onto my son's 04 Altima. Only thing I can say is do your research listen to both
positive and negative comments on the K&N filter and make a sound decision. Good
luck in whatever you do.
Mike
Old Oct 19, 2004 | 07:29 PM
JC_2k_SE's Avatar
i highly reccommend the K&N... and the GAB coathanger mod
Old Oct 19, 2004 | 08:12 PM
Whtmax'01's Avatar
i used k&n in camry for 140 k miles w out problems and had better performance with it, In the maxima i havent put in K&n becaue of fears of MAF blowing, its been 70k on maxima and so far MAF is still good, i think its becaue i used stock air filter. But if somebody can prove that even with stock filter MAF will blow then ill stand corrected.
Old Oct 19, 2004 | 08:27 PM
S00NR1's Avatar
OU > *
Originally Posted by mikelly
Soonr1,
Mike
Thanks Mike.....I actually just got done installing the Berk intake with the K&N cone filter and damn, am I impressed. There is definitely a major difference in the sound as there is an awesome deep growl now when WOT. Let's just say that I am VERY happy.
Old Oct 19, 2004 | 08:42 PM
Wow.. only a while ago you were looking at em GDs... good to hear that you got the Berk and have it installed... enjoy it!
Old Oct 19, 2004 | 09:51 PM
S00NR1's Avatar
OU > *
Ya, got the group deal from cobymoby at Berk and he got it here in about 4 days for 109.95 total -- very much worth it.
Old Oct 19, 2004 | 09:57 PM
Yeah I know... I got mine from him about a month ago...
Old Oct 19, 2004 | 11:03 PM
PrinzII's Avatar
OG and counting...
I have had 3 cars with the K&N ('88 Caprice, '94 Maxima, '02 Maxima). Personally, I like the fact you don't have to worry about it for 50k. In addition, when I cleaned the filter in the '02, I did not over-oil the filter. This was in the '02 for over 45,000 miles with no ill effects on the MAF.
Old Oct 20, 2004 | 10:40 AM
ISELKARS2's Avatar
Forget the K & N. I got mine then I got the INJEN cold air intake and WOWZERS what a difference!!! I've got only 5000 miles on it if you want to buy it. I've got the cleaner/charger kit too- $20 and you take care of shipping costs and it's yours!
Old Oct 20, 2004 | 10:51 AM
S00NR1's Avatar
OU > *
Why are you selling it?
Old Mar 6, 2005 | 02:49 PM
mike_bresnahan's Avatar
I've been using a K&N stock replacement filter for 1 year now and like it better than the throw-away filters. I live in an area where I have to replace a normal filter twice a year. It is great having a K&N that I can wash and put back in. This filter is actually saving me money!
I bought the K&N from AJ-USA. I have ordered from them twice and been completely satisfied both times.
Old Mar 6, 2005 | 05:25 PM
CoolMax's Avatar
is invisible
Don't forget to add the cost of the cleaning kit to the filter.
I'm sticking with the K&N panel filter from 3rd gen, I don't want any MAF issues.
Funny that Nissan has been using the same size filter since at least 1989.
Old Mar 6, 2005 | 10:24 PM
S00NR1's Avatar
OU > *
Wow, how in the world did this thread get dug up?
Old Mar 6, 2005 | 10:25 PM
I was wondering the same thing...
Guess we got grave-diggers lurkin about... I've seen worse though... and at least it ain't a
