View Poll Results: Do you warm your car up 1st thing?
yes
211
43.33%
no
72
14.78%
a little bit, like 30 seconds
204
41.89%
Voters: 487. You may not vote on this poll
do you warm up your car?
u know idle warming is bad for engines right? just stay below the speed limit/3k rpm for about 2 miles or when temp is right. that way the oil is circulating as it warms with the engine. a hot idle engine is no good.
my heat doesn't even turn on till the temp is normal. thank goodness for heated seats and wheel.
Originally Posted by spirilis
yeah, I start it up, let it sit a number of seconds (10-30), pull out, and drive it gently until the temperature gauge shows average, then I slowly get more aggressive with the throttle.
I give it about 30 seconds or so if its warm out, or about a minute if she's sat all night and its cold (which it is now).
Can someone *please* explain how a 900-1400rpm idle is BAD for an engine? Sure it'll get hot if you let it sit for a half-hour in the driveway, but come on...
From what I heard it can kill sensors like your 02 sensors and oil pools more in certain parts of the motor if left idling for excess periods.
Thanks, that sorta makes sense...but then again nothing really makes sense on new engines anyway. I still can't imagine 2 minutes in the driveway being more damaging than mashing the gas and finding 5k+ in 2nd gear
(which is fun!)
It's nonsense what idle is bad for engine. When you drive, engine needs to give much more power. Cold oil doesn't give proper lubrication, but you still force engine to push the car. It's much better to warm the oil without any extra work for engine.
And guys, don't turn the heater right the way. It's gonna blow cold air any way. And it's gonna take much longer to heat up the engine (and your heater too). If you turn it on, heater takes all heat from radiator, and you just make extra radiator cooling.
Wait few minutes, atleast till you can see that temp gauge moved some.
I let it warm up a couple of minutes, then drive keeping the rpms below 2500 until the temp is normal (fully warmed). With regards to the auto tranny, I keep the OD off until the temp reads normal and I park my car in my driveway so I dont have to reverse out on a cold tranny. I hear that reversing on a cold auto trans and letting a cold auto shift into OD drastically shortens tranny life. I was told this by a Chevy tech....figured it couldnt hurt.
Originally Posted by IgS
two words: remote starter
There was a huge thread about this a long time ago. Yes, you should wait until the needle is above C before you rev over 3000. No, you shouldn't let your car warm up for more than a minute or so if it's cold. One minute should be enough. Any more and it's overkill and not good for your engine. If it's warm outside, 30 secs is enough.
I've heard it's bad now to fully warm up, and frankly I don't care anyway. Who the hell has the time to sit and let their car warm up for 5 min? I'd rather buy a new one a few thousand miles earlier than engage in that tomfoolery. I personally start both cars and let them run for about 5-10 seconds, tops, then it's off to the races. Actually I do drive with low throttle and rpm until it's fully warmed up, but I never let it idle to warm itself.
Originally Posted by SkoorbMax
Unless it's scorching hot outside one minute isn't enough to get my temp gauge up to the C. On a cold day it would take at least 5 min.
). Our cars warm up very fast once you get moving, but not so much just idling.
I still say it's a little silly to waste engine cycles/gas until the coolant guage starts moving.
I would never warm a car up for itself, only warm it up so that it's nice and toasty for the passengers. That leather can get dang cold!!
i warm up my max every time i start it up depending on how cold it is especially in the morning when I have left my baby sit for many hours.. It doesn't take long an besides it seems like the car runs like crap if I just hop in it an drive when its the 1st drive of the day..
Dayam... we're still talkin about this? Anyways, since I read this thread last week or whenever, I've been a stickler for letting my car warm up for a minute, then driving below 3000 rpms until it warms up below C... haha... thanks for messin me up guys... jk, I know, its good for the car...
Ditto that. I start mine from inside the house. Let it run for about 15 min and the heater on full blast. Not only is the engine at operating temp, but so are the leather seats
I fail to see how the coolant temperature sensor moving makes the car ok to drive. The engine's already running. Any significant wear on a decently maintianed engine will happen within the first 5 seconds. Waiting until your coolant says it's ok to drive is a waste of time and gas.
Now if you're waiting for your car to warm up so that your butt and hands dont freeze. That's something else.
Want more?
http://www.wcr.ab.ca/news/2002/0128/...up012802.shtml
http://www.smartmoney.com/consumerre...t116&nav=CR_hp
http://www.consumerreports.org/main/...East_id=333153
thanks dmplus:
and ya'll said I was crazy for starting and just driving. Start her up, seat belt on, heated seats on, heated wheel on, sunglasses or headlights on, 30 sec. done. Just drive slowly.
Idling your car in the winter isn't just bad for the environment; it can be hard on your car's engine. Incomplete combustion means that fuel residues can condense on cylinder walls, contaminate engine oil and clog spark plugs. ...The best way to warm your car up is to drive it. With computer controlled, fuel-injected engines, you need no more than 30 seconds of idling before driving away.Things like wheel bearings, steering, suspension, transmission and tires only warm up when your car is moving.
Don’t let the car sit and “warm up” after it’s started; engines warm up faster while you’re driving
whats makes you a pro?
