Final words on the D2's *must read*
Old Nov 7, 2004 | 10:19 AM
  #41
Ammi's Avatar
350 Detroit Muscle
Originally Posted by raybone97-I30t
No unusual noise yet?
Old Nov 7, 2004 | 11:45 AM
  #42
raybone97-I30t's Avatar
no noise yet..hopefully none to come
Old Nov 9, 2004 | 09:54 AM
  #43
dblrr900's Avatar
OK. I got a little noise. Front Driver Side. Kinda of a clicking popping noise when I hit certain little bumps, maybe when turning at times. Not ALL the time, but a couple times a min. Guess I will contact Mike and see what the steps are to check into this. I know nothing is loose, we used air tools for all this.
Also.... the settings... Nothing to tell you really where to start, so:
Everyone who has these. When you start your settings, are you starting from the farthest Counter Clockwise setting? Then 1 full turn equals setting 1/0 correct?
Everyone talks about their ride being set at 2/3 or 4/5 does that mean 4 full turns, then set on position #5?
The Camber plates.... where is everyone setting theirs? Dead Center? Towards the outside? Inside?
Not a lot of info on these and the guy working with me had JICs and they actually have info and the settings are very clear...... Not as lucky with these.
Old Nov 9, 2004 | 10:27 AM
  #44
CUIT-Man's Avatar
Great questions, dblrr900. I should have a box of these for my 4th gen sitting at home as I am on a business trip right now. I expect to install these Sunday or Monday and hope to help shed light to the complete picture of the D2s. Do any instructions come with them?
Old Nov 9, 2004 | 10:29 AM
  #45
dblrr900's Avatar
No Instructions. A little common sense and some aggrevation at Nissan builders and you should be ok. I wouldnt recommend doing it alone. Can be a pain without a 2nd set of hands.
Old Nov 9, 2004 | 04:17 PM
  #46
skalberti's Avatar
I live life on the edge
Really one person is enough. I did mine alone. I would recommend using and break over bar instead of the air tools. Those don't really get things that tight. Especially on the bottom two bolts that mount to the steering knuckle.Those have to be VERY tight. Some of the things I read about a noise while turning, recommended loosening up the top bolt above the camber plate, 19mm I believe and then retightening snuggly. Hope this helps
Old Nov 9, 2004 | 04:28 PM
  #47
dblrr900's Avatar
Once it was all back together went once over everything with regular tools and made sure everything was tight. The bolts are all good on my end.
On mine we had some issues getting one side out from the stock setup. Seemed a little tight and having the extra guy helped get it out. If I were alone it would have been quite a bit difficult.
Skaliberti - what settings did you set your front and rear to? Like 4 turns from left on position #3 or what?
Old Nov 9, 2004 | 07:16 PM
  #48
skalberti's Avatar
I kept it simple. All were turned all the way toward "H" and left at that position. That is the softest.
Old Nov 16, 2004 | 07:28 PM
  #49
CUIT-Man's Avatar
Just got done installing them this evening. Not really any problems to speak of other than having to grind one of the holes on my strut tower brace a little to get the top of the coilovers to go through. Drove around - no noises, no issues, just quality stuff.
My point in buying these was for handling performance, not to dump the car on the pavement. I made them as high as I dared, giving the mounting piece more than half the length of threads of the shock, but I ended up with between a 1.25 and 1.50 inch drop in front and a (GULP) nearly 3 inch drop in the rear. It really doesn't match. I don't want to scrape my car constantly over curbs so I really don't want to lower the front to match the rear. What is the minimum drop anyone has been able to obtain on the rear of an A32?
Terrible pics, but at least they are pics:
Before:
After:
Close up of front after:
Close up of slammed rear after:
Old Nov 16, 2004 | 07:57 PM
  #50
Ammi's Avatar
350 Detroit Muscle
Man I can't wait till I install these. Won't happen for another 5 months though
Old Nov 16, 2004 | 08:05 PM
  #51
Greeneyes's Avatar
Cr@p I still cant get rid of the noises. Well I took them out a couple of weeks ago and I got rid of the noise that came from the coilovers when I turned, but now I can here a clunking noise when going over small bumps. Sounds like something is loose but Ive tightened everything up. I think its still the front right coilover making the noise but I havent made sure. Hopefully during the thanksgiving break I can recheck everything out and hopefully find what the issue is.
Old Nov 16, 2004 | 08:21 PM
  #52
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
What spring rates did u guys get?
Old Nov 16, 2004 | 08:27 PM
  #53
mattattax's Avatar
Hey all! I have Tokico Blues and H&R springs so I won't be getting D2s anytime soon. But everyone that gets them: please post comments on ride quality, service, etc...
Old Nov 16, 2004 | 08:40 PM
  #54
Ammi's Avatar
350 Detroit Muscle
whatever rate the came w/
Old Nov 16, 2004 | 10:11 PM
  #55
lower that front...lol....mine is about 2.7 frnt/back ....have the reccomended springs, and have my front dampening set at 6/36 and the backs at 10/36..........no particular reason for those setting other than comfort..this is the combination that I like....might have to raise it up some tho,, might be getting a job in d.c., ..i had a few noises here and there,, but they seemed to work themselve away.. when the weather dropped to 28F, thats when the noise started...maybe they need to warm up a little? i dont know...I love em tho.. and the slammed look is so much better...
Old Nov 16, 2004 | 11:30 PM
  #56
Larrio's Avatar
The Definitive AE Master
I have it low also, no rubbing on curbs or anything like that. My noise is 99% gone after tightening up the plates, changing out the right front strut, reassembling the coilovers, and making my own custom gaskets.
front
rear
Old Nov 16, 2004 | 11:38 PM
  #57
skalberti's Avatar
dismantle the coilover and check the strut
Old Nov 17, 2004 | 09:27 AM
  #58
Greeneyes's Avatar
how do I check the strut to see if its blown?
Old Nov 17, 2004 | 05:34 PM
  #59
skalberti's Avatar
When dismantled, press the piston on the strut all the way in and watch the rebound. It should be fast smooth and quiet. No noises or popping. If it extends back out slowly, its probably bad.
Old Nov 17, 2004 | 06:58 PM
  #60
Larrio's Avatar
both of mine don't extend back out fast. Rather very smoothly, but no shooting upwards type of speed.
even the replacement I got from urbanimport is the same
Old Nov 18, 2004 | 10:24 AM
  #61
Greeneyes's Avatar
OK Thanks...I'll be checking this when I get home this weekend.
Old Nov 18, 2004 | 02:54 PM
  #62
PearlRalizinG2k's Avatar
for those of you who said that you are satisfied with the ride, what spring rate did you get????? the question has been asked many times and not answered yet.
Please help us
Old Nov 18, 2004 | 02:57 PM
  #63
skalberti's Avatar
Originally Posted by TopElement
Ummm, no. Blown struts will not move slowly. If it's blown, it has very little dampening effect, which would make the piston move freely.
Mine did and the strut was blown as did the stock struts when they were removed. They had no rebound at all. Remember they are pressurized. Maybe your talking about while they are mounted on the car, then yes they will move freely and have little dampening. I was referring while the strut was off the car.
Old Nov 18, 2004 | 03:19 PM
  #64
CUIT-Man's Avatar
With the strut off the car, if you can very easily move the piston up and down by hand, then it is blown. I have experienced struts so old and blown that the piston will fall into the strut body with just the force of gravity when you let go of is after extending it. It should be very difficult to compress and rebound the piston by hand.
Old Nov 18, 2004 | 03:42 PM
  #65
Larrio's Avatar
Please help us
9F/7R. Lets remember folks, the ride will be on the stiff side on rough roads if you go with any type of coilover system.
Old Nov 18, 2004 | 03:46 PM
  #66
looslip's Avatar
Horra!!
So is the verdict on a blown shock that, on a good shock you should not be able to derpress the piston at all? For all the struts that I've had in the past (New, not coilovers) I've been able to depress the piston down all the way and the piston would come back up slowly and smoothly, like Larrio said. Is that a point of difference between regular shocks and coilover shocks? I'll be getting D2's soon and I want to make sure that they are good when they come in.
Old Nov 18, 2004 | 04:10 PM
  #67
CUIT-Man's Avatar
I am actually VERY suprised how civilized this is. I had a 98 Sentra SE with AGXs and Eibach Prokits and that was "stiff." This setup is butter in comparison. Even with the shocks set to full stiff it's nothing like the other setup. I'm almost dissappointed that at full stiff all around that I can't really jar my kidneys...
Old Nov 18, 2004 | 04:31 PM
  #68
Larrio's Avatar
you have some tough kidneys. Driving in L.A. for a few minutes at full settings would be suicide for me
Old Nov 18, 2004 | 04:36 PM
  #69
steaLthyMax's Avatar
That's why we're born with two of them
Old Nov 18, 2004 | 04:38 PM
  #70
frankieduxAE's Avatar
LA Roads OC Roads the cities have so much money down here they repave perfect streets after a few years of "abuse"
gotta have smooth streets to go along with the acres of palm trees.
Old Nov 18, 2004 | 04:48 PM
  #71
looslip's Avatar
Horra!!
I know someone with D2's in their Nissan 240sx that say that D2's are much softer than any other coilovers he's had or has rode on.
Old Nov 18, 2004 | 04:51 PM
  #72
Ammi's Avatar
350 Detroit Muscle
So what's the verdit on blown struts? Very slow rebound or fast rebound?
Old Nov 18, 2004 | 04:56 PM
  #73
I would think no rebound or a fast rebound..a slowly rebounding strut is a good one
Old Nov 18, 2004 | 08:49 PM
  #74
Triple8Sol's Avatar
I miss the .org!
Can you also tell by when you push it in? Shouldn't a new strut be harder to push in than a blown one?
Old Nov 18, 2004 | 08:50 PM
  #75
Triple8Sol's Avatar
I miss the .org!
I didn't see it mentioned in this thread or the GD thread, so here's a question for you guys: dblrr900, K Pazzo 6, skalberti, Larrio
What spring rates F/R did you guys end up going with?
Old Nov 18, 2004 | 11:01 PM
  #76
Larrio's Avatar
i opted for 9F/7R which is the default spring rate since its closest to the JIC A2's at 9F/6R
Old Nov 19, 2004 | 06:01 AM
  #77
dblrr900's Avatar
I got the standard Setup. Just ordered a set. Really didnt know what to try and get other than the standard offering. Didnt want to mess with the basics.
I am very happy with these. I do need to drop them out this week though and put the gaskets on the front. They are making a creeking noise and I know that is the cause. Once that is done, they are going to be fine. The ride is jarring when you hit a hard one, but other than that, very stable and decent. Then again, I had coilovers on other cars and am used to this kind of ride.
If you like the stock feeling.... there is NO way you will achieve that with a coilover.
Old Nov 19, 2004 | 06:03 AM
  #78
2kVQboodah's Avatar
i've just heard about D2 coilovers and people's feedback sound good to me, are those coils german or japanese parts??
Old Nov 19, 2004 | 06:44 AM
  #79
nadeemp8's Avatar
front
rear
Do you have any pics of the gaskets you made? Also what were they made of and where did they go? I'm in the GD on the D2's and have an AE and am ineterested. Thanks!
Old Nov 19, 2004 | 09:18 AM
  #80
D2 Coilovers are M.I.T. = Made In Taiwan.
www.d2racing.com.tw
