Sport suspension package owner, please come in!!!
Old Apr 14, 2001 | 04:06 PM
LoveSick's Avatar
I am just wondering if you guys are happy with your sport suspension on your Maxima AE or SE. I had mine for 14k miles and I am not sure if I should replace the struts due to wearing.
Anyone feels like they should replace theirs because of the bumps and lumps on the ground?
In the place I live in, the bumps and lumps were every where.....
Do you guys think the Maxima struts will last longer than the ones on the 4th gen which I had to replace after 2 years?
Old Apr 14, 2001 | 04:19 PM
punkdork's Avatar
The stock suspension wasn't really tough enough for me. I now have eibachs on and will be getting tokicos soon. If you plan to replace your struts, go aftermarket.
Old Apr 14, 2001 | 04:27 PM
LoveSick's Avatar
did you feel the struts loses its damping after ecessive use? I know that Koni lasts a life time plus they allow lowering with stock springs!
WHen you mean tough, did you mean durability or performance?
Old Apr 14, 2001 | 04:29 PM
punkdork's Avatar
When I say tough I mean performance. As far as whether or not their performance is lagging.. I don't know cause every 5k miles or so I have added some suspension mod eheh. I can tell that the stock struts can't handle the eibachs which is why they are about to get the boot.
Old Apr 14, 2001 | 04:41 PM
LoveSick's Avatar
Could you do me a favor? Try to press your stock springs and see if they are compressable....
If they are hard enough, I might just as well go with Koni with stock springs since the sport suspension on the SE costs quite a bit.......
Old Apr 14, 2001 | 07:29 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
No need to replace your struts at 14K unless you have Eibachs on.
Old Apr 14, 2001 | 07:39 PM
punkdork's Avatar
I'd love to test this for you but my stockers are in the hands of UPS currently.
Old Apr 14, 2001 | 07:42 PM
Y2KevSE's Avatar
Ohhhh... the stock springs and the Eibachs can be compressed somewhat by hand.
Old Apr 14, 2001 | 07:58 PM
AznWontonboy's Avatar
struts?? u need to replace the stock struts even if you have the se suspension?? and they get worn out?? hm...
Old Apr 14, 2001 | 08:00 PM
punkdork's Avatar
You really shouldn't need to at 14k miles.. but if you wanna upgrade... then its go!
Old Apr 14, 2001 | 08:02 PM
ahh thanx.. but wuts a good time to change ur struts?? and wuts the difference between shocks and struts?? mah bad for my lack of suspension knowledge
Old Apr 14, 2001 | 09:50 PM
one more question.. do the stock sport suspension need ta be replaced ever???
Old Apr 14, 2001 | 09:59 PM
LoveSick's Avatar
SHocks = struts whatever u like to call it! (I think)
I don't know...Since the se shocks have a pretty high damping rates, in theory they should last a little longer? Am I right?
In my opinion, ride is very tight with the SE and handling is very good. But since the place I live in has tons of lumps and bumps, I always have the feeling that my shocks should be replaced by Koni which should last a life time.
But I feel that my shocks are pretty hard still after all the bumps I hit almost every day. Can some expert tell me if the SE shocks are built to last?
Old Apr 14, 2001 | 10:23 PM
punkdork's Avatar
As I see it.. basically shocks are just the individual absorbers... most newer suspension systems use struts which is basically a system where the spring goes around the shock and there are caps on the strut(or shock) that hold the spring in place...
Old Apr 14, 2001 | 11:05 PM
UMD_MaxSE's Avatar
Got Bent?
I think the stock SE suspension is decent in terms of performance. I would not mind a stiffer, better handling ride though. You will feel a lot of bumps and road imperfections even with the stock SE setup.
Fbana41
Aug 29, 2016 12:18 PM
maxima-junky
Oct 7, 2015 06:13 PM
videomano
Sep 8, 2015 03:28 PM
Adoubi21
Dyno Discussion and Slips
Sep 7, 2015 09:34 AM
