3.5 Cam specs?
Old Nov 4, 2004 | 05:32 PM
japmaxSE's Avatar
Go Get a Life!
3.5 Cam specs?
Can someone please provide me with stock specs on 3.5 cams Deg? Lift? etc.
For 02' 03' 04' and the 350Z "if there not the same".
Old Nov 5, 2004 | 05:38 AM
japmaxSE's Avatar
Go Get a Life!
________________________
Old Nov 5, 2004 | 08:14 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
VQ35s are internally the same except the first gen Pathfinder(240hp) and now AE 350Z.
Anyways, with the CVTC off, the FSM says:
Old Nov 5, 2004 | 08:16 AM
IceY2K1's Avatar
Forgot to add, lift is 9.2mm.
Old Nov 5, 2004 | 03:23 PM
japmaxSE's Avatar
Go Get a Life!
Thanks for the injector ? So it can be done but I don't have 00',01' LIM
SR20 Says The 3.5 injectors actually flow less than the 3.0 injectors at the same pressure.
Sorry but I'm having trouble reading this.
I'm trying to compare them to Jimwolf cams 4th gen S1 VQ30DE BILLET CAM SET 256 DEG .415" GROSS LIFT.
So the AE 350Z is not the same but the other 350 models are.
Old Nov 5, 2004 | 03:28 PM
IceY2K1's Avatar
Yes, injectors on the VQ35 Maxima flow 270cc, but on the VQ30 Maxima/350Z they flow 290cc.
Old Nov 5, 2004 | 03:36 PM
japmaxSE's Avatar
Go Get a Life!
So the AE 350Z cams is not the same but the other 350 models are.
________________________________________
Old Nov 5, 2004 | 03:46 PM
IceY2K1's Avatar
JWT have 10.541mm lift vs. VQ35 9.2mm. JWT have 256 duration vs. VQ35 238-240 maybe?
Anyways, if you're using VQ35 cams, get Tomei not JWT.
Rumor says Nismo rod bolt to support higher RPM and I think bigger cam, but I could be wrong.
Old Nov 5, 2004 | 03:52 PM
SR20DEN's Avatar
VQ Wizard
I measured the stock cams at 9.5mm lift. I wonder where this 9.2mm figure keeps coming from?
And you don't have to waste your money on that worthless JWT crap. Just buy Tomei or Nismo 350Z cams and use them. They can easily be made to work.
Old Nov 5, 2004 | 03:54 PM
SR20DEN's Avatar
VQ Wizard
You forgot to mention this is at 3.0 Bar. The A33B uses a fuel pressure of 3.5 Bar which effectively makes the injectors 315cc. This is what the world can't seem to understand.
Old Nov 5, 2004 | 03:55 PM
IceY2K1's Avatar
Old azz published SAE document...so probably not 100% current anymore, just what I refer too since I don't remember off the top of my head.
Old Nov 5, 2004 | 03:58 PM
IceY2K1's Avatar
True.....
VQ30 290cc@3bar(2000-2001 Maxima)
VQ35 290cc@3bar(2003 350Z not sure on 2004.5+)
VQ35 270cc@3bar(2K2+ VQ35 Maxima/Altima)
Old Nov 5, 2004 | 04:44 PM
japmaxSE's Avatar
Go Get a Life!
Wow Tomei cams are expensive SPECIAL ORDER
Old Nov 5, 2004 | 04:48 PM
IceY2K1's Avatar
Did you check here?
http://store.yahoo.com/sgpracing-store/tomei1.html
Old Nov 5, 2004 | 04:49 PM
japmaxSE's Avatar
Go Get a Life!
True.....
So I should stick with VQ30 INJ and bump the pressure up when needed for more fuel with the aid of a A-FPR.
Correct me if I'm wrong, can you use a diffrent FPR off another car.
Old Nov 5, 2004 | 04:53 PM
IceY2K1's Avatar
Yes, it wouldn't do you any good to switch to stock VQ35 injectors unless 2004.5+ are bigger then 290cc@3bar. There are aftermarket injectors that are bigger though.
You can raise fuel pressure, but depends on what setup you're planning.
Old Nov 5, 2004 | 05:05 PM
japmaxSE's Avatar
Go Get a Life!
true
For now stock is good but I want to play with it a little raise the bar.
My setup is similar to Tilleys.
Old Nov 5, 2004 | 05:13 PM
IceY2K1's Avatar
Which one? LOL! VQ35 shortblock w/VQ30 heads, right?
Walbro will bump up the fuel pressure a bit, so you'll have plenty of fuel NA.
Old Nov 5, 2004 | 05:24 PM
japmaxSE's Avatar
Go Get a Life!
_______________-
Old Nov 30, 2004 | 12:57 PM
IceY2K1's Avatar
Any updates?
Looks like you tried the VQ35 cams in your VQ30 heads, but too short?
Have you looked into the JWT "sprocket adapters" for the 2000-2001 VQ35 Pathfinder as a possible solution?
jmlee44
Oct 2, 2022 02:13 PM
Quickywd01
Sep 21, 2016 09:36 PM
09maxshawn11
Sep 30, 2015 10:28 AM
