TTZ Calipers
Old Nov 6, 2004 | 12:20 PM
A33 VQ30DEK's Avatar
TTZ Calipers
hey guys,
I was wondering if i had 18x8 37mm offset wheel, would i need spacers to clear 30mm TTZ calipers or should i go 26mm?
Old Nov 6, 2004 | 01:38 PM
WildmanAL's Avatar
It all depends on your spoke pattern. I would get the 37mm..... you might have to get 5mm spacers.
Old Nov 6, 2004 | 02:07 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
clears my 38mm offset Enkei RPO1s. I have 30mm Aluminum ones from an actual GT-R Bling bling.
Old Nov 6, 2004 | 09:54 PM
Jeff92se's Avatar
I'm needing a caw
Offset is not the only factor. Design of the wheel is as or more important.
Old Nov 7, 2004 | 01:53 AM
well i have the Volk GT-N, theres a pic in my sig.
http://img.photobucket.com/albums/v1...D/f680e56f.jpg
Old Nov 7, 2004 | 09:20 AM
Jeff92se's Avatar
I'm needing a caw
As a general guess, most volks provide good clearance. How much clearance to have now? From the end of the caliper to the inside of the spokes
Old Nov 7, 2004 | 03:23 PM
WildmanAL's Avatar
Well with Matt's kit and the 300zx calipers measure from the center of the board 5.25" out to a spoke. From that point you should have atleast 2.5" to the rotor if you're going to get 300zx calipers.
Old Nov 7, 2004 | 05:36 PM
Larrio's Avatar
The Definitive AE Master
there is a high and low disk setup for volks. Check which ones you have. High disk = thick hub, designed for clearing brakes
Old Nov 8, 2004 | 01:48 PM
hey jeff,
it seems as if you are the one that makes the brackets for the 300zx calipers with the cobra rotors. How much for the bracket and all the hardware necessary to install this brake kit.
Old Nov 8, 2004 | 01:50 PM
Jeff92se's Avatar
I'm needing a caw
I only provide the brackets. Which are $45 shipped. But since you have a 2000+ maxima, you will have to even modify these brackets. ie.. drill one set of holes out to a bigger size. Don't know if you want to do that. If not, it might be easier to buy Matt93se's bbk kit. It uses a slightly smaller rotor 12.5" but it's ready to bolt on
Old Nov 8, 2004 | 01:52 PM
i guess i might do that then
thanks jeff
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
Bonka
Sep 14, 2015 11:18 PM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
