puting reverse indiglo on...
Old Nov 13, 2004 | 04:20 PM
Jackboot's Avatar
can i move the needles on my cluster and they will go right back to where they are supposed to be or will it mess them up??
Old Nov 13, 2004 | 04:33 PM
Jackboot's Avatar
also, do you double-sided tape them on there?
Old Nov 13, 2004 | 05:32 PM
2KGrey's Avatar
I was able to carefully bend the indiglo gauge face so that it fits over the needle. I don't think the needle will bend much, so be very,very careful. The gauge face doesn't get taped or glued (at least mine didn't) it's held in place by the placement pins and the black bezel.
Now, all I need to do is get the needles a little brighter...
Old Nov 13, 2004 | 06:29 PM
Jackboot's Avatar
well i put the gauges on but they get stuck when i move them around... how should I remedy this problem???
Old Nov 13, 2004 | 06:35 PM
2KGrey's Avatar
The needles get stuck when they move? If so, I would check to see if the new gauge face is bowed or bent. There's not alot of space between the bottom of the needle and the face of the gauge.
Old Nov 13, 2004 | 06:40 PM
Jackboot's Avatar
yeah, taping those parts down might get rid of it or i could sand down the bottom of the needles a tiny bit... any suggestions?
Old Nov 13, 2004 | 08:33 PM
2KGrey's Avatar
I had one that was binding the needle a little. I was able to move the indiglo gauge face around until it no longer touched.
BTW,
I have a 2000 and the gauge faces are separate pieces. The gauges for the 2002-3 should be one piece, I think. Which kind do you have?
Old Nov 13, 2004 | 10:12 PM
Jackboot's Avatar
I have a 2k1 but i have gauge faces for a 2k2 so its 1 piece...
Old Nov 14, 2004 | 11:15 AM
Jackboot's Avatar
another question.... does anyone have a wiring diagram of the wires on the back of the switch??
Old Nov 17, 2004 | 01:49 PM
MaximaDudes's Avatar
does anyone have a write up with pics? i wanna add the indiglo gauges but im afraid ill break something. thanks guys
James92SE
142
Jan 2, 2024 09:23 AM
dcam0326
Sep 18, 2015 04:52 PM
Lilfatz301
Sep 18, 2015 08:06 AM
lrb6805
Sep 17, 2015 04:49 PM
