is it worth to install remote start on a stock alarm?
Old Nov 22, 2004 | 10:17 PM
Zaypka's Avatar
is it? im owner of 2002 6spd
Old Nov 22, 2004 | 10:49 PM
mikeI302k's Avatar
depends on how much they want for it. if its a resonable amount then it might be since a remote start that is good is about 400 ish usually more. yes the range isent anywhere near as good but you get what you pay for.
Old Nov 23, 2004 | 01:42 AM
FanaticMadMax's Avatar
That would be difficult to say. First of all, how do you start the car since it's a manual tranny. You have to have the clutch engage to start the engine, right? Secondly, that you probably gonna deal with a lot of wiring to the factory alarm where as that you'll have two remote, one for disabling the alarm and two for starting up the car. I'm not sure if that would give you an idea that you have to consider.
Old Nov 23, 2004 | 01:48 AM
kpr10is's Avatar
Zaypka, how would you go about doing this? I install for Circuit City and I cant say Ive ever seen a stock alarm for everything except the remote start. If you really want the remote start, spend the money and get like a Viper 560xv for example. FanaticMadMax, there is a safety switch that goes to the brain of the alarm. There is a wire on the ecu that is grounded when manual trannys are in neutral, and you tap into this wire, and run it to the alarm brain so it only starts when the car is in neutral. You do get what you pay for which is why Directed Electronics (Viper, Clifford, Valet, etc) are expensive. You will pay as much for the installation as you will for the alarm though, remote start installations arent cheap, we charge 160 at Circuit. You should really find someone from the org in NY because most shops will not install remote starts on manual trannys to begin with. The Viper 791xv is also a very popular one, just do your research, theres plenty of info on the web about all this. Hope this helps
Kevin
Old Nov 23, 2004 | 08:18 AM
Manaz101's Avatar
Get ahold of Don (Pearl96Max), i think he installs the Viper 791 for about $450 and he's in the NY area.
Old Nov 23, 2004 | 01:06 PM
maximalex's Avatar
^ What he said.
Old Nov 23, 2004 | 09:53 PM
Zaypka's Avatar
i did, he told me everything, but its a hard decision for me either leave the stock one or go aftermarket. I'm just confused. and i don’t wont to spend more then $350 for alarm.
Old Nov 24, 2004 | 09:18 AM
Max96GLE's Avatar
Try what i did. Learn the tricks and install yourself.
Old Nov 26, 2004 | 01:14 PM
Manaz101's Avatar
I hear you, i personally can't see spending that money on an alarm when my factory alarm works just fine.
JRod28
Dec 29, 2023 09:56 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
maximaham
Aug 7, 2015 01:11 PM
