02 max engine knock!!!
Old Nov 23, 2004 | 03:11 PM
Jay_pee99's Avatar
About a week ago, i went to start my car and the car struggled to start so i turn it off and tried again. Well.... it started but was followed by a loud knocking sound coming from the front right cylinder which sounded like a man with a hammer trying to get out. I only have 50K miles but i scared to put in the shop b/c my mods could void my warranty. Has anyone had the problem b4 or have any idea of what it could be? By the way it's a 6speed.
Old Nov 23, 2004 | 03:56 PM
HotMax03's Avatar
Damn that really blows, dude. Sorry to hear that man.
Old Nov 23, 2004 | 04:09 PM
GuZo's Avatar
I am having the same problem right now, I think. I took my car into the dealer today and one of the techs took it for a ride and told me he never heard something like that. He said it sounded like a jackhammer 2 blocks away.
My car will be in there tomorrow all day.
It only happens under light-medium acceleration and has gotten worse in the past few days.
Old Nov 23, 2004 | 04:13 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
let the guy with the hammer out you bastards!!!!
kidding----------that sucks my car has 49500 hopefully its not a 50k thing with all the 5th gens..........
Old Nov 23, 2004 | 04:22 PM
Jay_pee99's Avatar
If possible can you give me an update on what it is
Old Nov 23, 2004 | 05:06 PM
Matt_01SE_20th's Avatar
i just read a post below saying that the crank sensor needs to be alligned not only with bolts but with a dimple or something. this causes an offset in teh timing and causes knock. just what i read.
Old Nov 23, 2004 | 05:29 PM
spastic's Avatar
I've been dealing with this forever. PLEASE!!!! if anyone finds a cure post it or PM me. I'm desperate to find a fix. I called Nissan Consumer Affairs today to ask them what to do but gave up after being on hold forever.
Old Nov 23, 2004 | 07:31 PM
GuZo's Avatar
How loud are your knocks? Mine is really loud, it can be heard inside the car with the windows closed and people outside walking hear it too.
Old Nov 24, 2004 | 05:49 PM
spastic's Avatar
GuZo: Same thing here.
Old Nov 24, 2004 | 08:45 PM
GuZo's Avatar
Didn't go to the dealer today, something came up. Will go friday if possible or monday.
Old Nov 24, 2004 | 09:25 PM
F23A4's Avatar
Good luck Guzo. So far, so good here w/my 02 @ 33k.
Old Nov 25, 2004 | 01:35 PM
hawaiiankine's Avatar
sounds like it could be a timing issue. Does it do it on start up or only under exceleration? Carefull driving it,,, don't want to detonate if it is. Also it could be your timing chain or a push rod. Let me know what the dealership finds out. You would think your SES light would come on or something. Damn little people with hammers...
Old Nov 25, 2004 | 03:46 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Nissan doesn't use pushrods in any of their engines, as far as I can remember they never even had a pushrod actuated OHV head design on any of their vehicles- even Datsuns. Sounds like a spun rod bearing or something- which I never heard of on a VQ engine. When you spin a rod bearing it sounds like someone is beating on the engine internally- and it tends to come right from the top of the engine- head. I have spun bearings on SR20s before and it sounds like someone hitting the engine with a hammer inside. Let us know what the dealer finds, I'm currious myself.
Old Nov 25, 2004 | 06:04 PM
NYC TAR's Avatar
I also started having the same problem, but I was using regular gas. I start using BP premium gas yesterday, but I didn't push it because it was raining. BlackBird, also when I brake to a complete stop the RPM jump little up and goes down very fast causing the car jerk foward ( like the tranny down shift). Black bird do know what is causing this problem ( TB, tranny, spin rod bearing )
Also I got a hi idle code (about 990 RPM) last week, but the dealer reprogram back to spec with the consult II. Righ now I'm about 550 RPM for the Idle.
thanks Jeff
Old Nov 26, 2004 | 10:20 AM
mattito's Avatar
Same here! I cant find a tech who has an idea what it is. Also on 3 test drives w/ mechanics the noise didnt happen.
Old Nov 26, 2004 | 10:40 AM
GuZo's Avatar
Car is in the dealer as we speak, went in at about 11 am, I told my service advisor about the crank issue, the screws not being the only thing needed adjusted but the dimple as well.
I'll post later after I pick the car up to see what they say.
I just hope it's covered under the 50k powertrain warranty, it should right?
Old Nov 26, 2004 | 09:25 PM
NYC car, did you by any chance clean out your throttle body recently ? sounds like a deffective throttle body assembly to me.
Old Nov 26, 2004 | 09:34 PM
maximadave's Avatar
detailerdaveb@gmail.com
I'm curious on what the dealer said...
Old Nov 27, 2004 | 05:02 AM
NYC TAR's Avatar
Blackbird -kind of because when I install back the stock intake I took a look in inside the plate.
It just very annoying because you have hold the brake hard or else the car would jump foward.
all right,
Jeff
Old Nov 27, 2004 | 10:10 AM
GuZo's Avatar
The dealer told me the car was low on oil. My service advisor is a pretty cool guy and knows they're the only ones who touch my car so on the receipt he put 35699 instead of 37180 miles so that in case something stems from the car being low on oil, it will be covered under warranty. The car was low 2 quarts.
What's funny is when I went there the first time, I told them that the oil light blinks everytime I turn on the car and they heard the noise and they refused to check the oil simply for my state of mind.
Service advisor was cool enough to order me a new Bose HU without even reproducing the problem, and also a new climate control unit because a couple of the lights went off on mine.
So, all said and done, I would reccomend you guys to check your oils. I picked up the car and the noise is gone indeed.
Old Nov 27, 2004 | 12:10 PM
ddpack's Avatar
Even my wife knows how to check the oil!!!!!!
Old Nov 27, 2004 | 12:40 PM
Zero Deuce SE's Avatar
How did such a new car get half a gallon low on oil? Do you have any leaks or oil burning issues?
Old Nov 27, 2004 | 01:17 PM
njmaxseltd's Avatar
Good question!
Old Nov 27, 2004 | 01:41 PM
So I take it your getting a new engine ? You most likely spun some rod bearings like I said. Plus who in their mind doesn't check their oil ? I usually use the 2nd trip meter just to know when 3K miles is around the corner to change it. I don't use no oil change reminder stickers like some people do. I got 100K miles and my car don't burn any oil, I don't even check it !
Old Nov 27, 2004 | 02:07 PM
I know what you mean about not checking your oil and not burning any. I had 100K miles on my 92 SE before I traded it and it never used any oil between changes. I would only check it right before I changed it and right after. It was always on the full mark.
Old Nov 28, 2004 | 09:01 PM
Jay_pee99's Avatar
hmmm... I just changed my oil. I was using 5w30 synthetic but i just switched back to 10w30synthetic for the winter. But everytime i changed my oil it always looked alittle low to me. But i have know leaks! Where you getting the knock from one cylinder or all cylinders. I going to check my oil tomorrow just to see what happens.
Guzo: when you got your car back did it still have a knock?
Blackbird: Could throttle body cleaner cause a engine knock? B/C i cleaned my throttle body the same day i changed my oil. But didn't get the knock until a week later!
Old Nov 29, 2004 | 12:19 AM
There is no need to switch oil weights just for the winter. Our cars are designed to use 5W30 for all seasons for maximum fuel economy. Besides that, 5W30 would be better suited for the winter versus 10W30 anyway.
Old Nov 29, 2004 | 06:07 AM
F23A4's Avatar
Who's your dealer Guzo?? Hillside Nissan?? Lynnes?? Your service guys seem pretty cool compared to mine (Acme Nissan - Monmouth Jct, NJ)
Old Nov 30, 2004 | 11:53 AM
GuZo's Avatar
Hillside Nissan, if you go there ask for Andy and tell him Antonio Cunha sent you.
MAXSE5SPD
Sep 17, 2022 04:00 AM
CorollaULEV
30
Aug 9, 2021 08:11 PM
Slamrod
Sep 3, 2015 07:38 PM
raffivegas
Aug 23, 2015 09:54 PM
