o2 help!
Old Nov 28, 2004 | 03:21 PM
mahvelus's Avatar
SES P01071 and P01074
Whats up people.
Maxima 2k GLE
Service Engine Light soon ON
Reading : P01071 and P01072
The guy told me i have to change my o2 sensor...but he doesn't know wich one... can you guys help me out?
Is it really the o2 sensor that i have to change? or could it be something else?
Mahvelus
Old Nov 28, 2004 | 04:15 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Originally Posted by mahvelus
Whats up people.
Maxima 2k GLE
Mahvelus
it could be the o2 sensor along with a few other things such as the maf (mass air flow) or even a vacuum leak. you may want to have an obd2 reader check the o2 sensors to see if they are in spec. if its fine and you cannot locate a vacuum leak then its most likely the maf. nissan has an updated part for the maf as the original had a fairly high failure rate.
Old Nov 28, 2004 | 04:31 PM
Zero Deuce SE's Avatar
Whats up people.
Maxima 2k GLE
Mahvelus
Those 2 codes (P0171-P0172) are for fuel injection system lean and rich respectively. As sloppymax said, it could be caused by several things.
P0171
*Intake air leaks
*Heated O2 sensor 1
*Exhaust gas leaks
*Incorect fuel pressure
*Lack of fuel
*Mass air flow sensor
*Incorrect PCV hose connection
P0172
*Heated O2 sensor 1
*Injectors
*Exhaust gas leaks
*Inccorect fuel pressure
Old Nov 28, 2004 | 05:16 PM
mahvelus's Avatar
Thanks a lot for your answers, i guess i'm just going to bring the car to nissan and they will deal with it!
Thanks again.
Old Nov 28, 2004 | 05:19 PM
Yer welcome mane.
