JUst got a Fake K&N, check it out!
Old Apr 18, 2001 | 05:17 PM
LoveSick's Avatar
I think most rice are using this filter right now. This thing is made in raiwan and its neither paper nor foam. It was designed to be like K&N. It claims to ADD horse power. Which I doubt will be alot.
I want to test it out, anyone know where to get the adapter to install this POS?
Old Apr 18, 2001 | 05:31 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Check your local speed shop, because you might need to try a couple adapters to find one that works. One of my local performance shops makes their own for any application, so you might get lucky here at http://www.motorsportswarehouse.com/ .
Old Apr 18, 2001 | 05:35 PM
UMD_MaxSE's Avatar
Got Bent?
That is the filter that cone intakes like the JWT popcharger and Stillen hi-flow intake use. You would need one of those to use it. Some people have complained of pinging and loss of low end torque when they used these type of underhood intakes. But, they do provide gains at higher revs. If you are going with an OSCAI setup, you don't need one of these.
Old Apr 18, 2001 | 05:38 PM
LoveSick's Avatar
Wow, are the stillen and JWT units K&N? because I know for sure this one isn't K&N and I have one right here by me! I will just forget the OSCAI if this specific filter provide power....
Old Apr 18, 2001 | 05:42 PM
mzmtg's Avatar
Minister of Silly Walks
You can usually find those adapters on Ebay...
Old Apr 18, 2001 | 08:52 PM
Paul6speed's Avatar
Re: !
The Stillen cone intake uses a K & N. The JWT uses an imitation K & N.
Old Apr 18, 2001 | 08:55 PM
punkdork's Avatar
Re: Re: !
...and neither have that big hole in the middle...
Old Apr 18, 2001 | 09:04 PM
Paul6speed's Avatar
GR8BONE used or uses the same intake. He dyno'd 1 HP higher than I did last summer. At the time I was using a JWT.
Old Apr 18, 2001 | 09:27 PM
AznWontonboy's Avatar
go for OSCAI.. better gainsss as people say.. i might have make my OSCAI but im too lazy...
Old Apr 18, 2001 | 10:01 PM
irvine78's Avatar
i don't know about the actual gains of OSCAI but you can find the Nissan adaptor at almost any speed shops. if they don't have an exact one to fit your car, they can always make it fit!!
i know this cuz i used to have one of those until i bought a Stillen Hi-Flow.
Old Apr 19, 2001 | 08:56 AM
Jeff K's Avatar
Go to Home Depot
I just installed this exact filter on my car. The filter was $24.99 at PepBoys and I went to Home Depot for some mounting ideas. I found a bracket that is used for electric conduit. The bracket looks just like the normal mounting brackets for the cone filter but it's $9 and made of aluminum. The bracket center is 2.75 inches and will fit the filter perfectly. For $34, it's a cheap mod that I think helps.
Old Apr 19, 2001 | 11:01 AM
LoveSick's Avatar
Re: Go to Home Depot
Did this filter help your performance? THis is a cheap filter and I think it isn't that great. I got ripped off and got mine for 100 CAD. Did any of you find gains from this filter?
Old Apr 19, 2001 | 12:38 PM
Jeff K's Avatar
Re: Re: Go to Home Depot
I think so, the car revs quicker and gets off the line alot faster. I'll be taking my car to the drag strip in a few weeks, that will be the real test.
Old Apr 19, 2001 | 01:14 PM
Jon91SE's Avatar
Pusssseeeehhhh
They sound nice but sound is not a accurate measure of speed, try driving around in busy traffic on a summer day and see how much that intake gives you then, you will loose more then you gain, but if you decide to go with an underhood filter go with JWT...its got a velocity stack and its flat out bigger then those cheap generic cones ( of course i need to take my own advice seeing i have one of them too )
Old Apr 19, 2001 | 06:16 PM
LoveSick's Avatar
Re: Re: Re: Go to Home Depot
You found that this filter gave your car a moother rev? What other mods do you have besides the intake? Maybe this litlle intake isn't a rip after all!
Old Apr 26, 2001 | 12:39 PM
Gr8bone's Avatar
Yeah I have the same setup with the same cone and an adapter that came with the conefor under $50 shipped.
I had to shave the four holes on the adapter to fit my intake screws into their holes.
after it was on I could screech my 17" tire for about a second longer than before with my k&n panel filter and before my k&n I was usually unable to screech them at all unless the road had dirt or pebbles on it.
pics here of the install:
mine
http://members.nbci.com/gr8bone/myintake/
russ'
http://members.nbci.com/gr8bone/intake/
and heres my dc meet dyno results with the cone on:
http://members.nbci.com/gr8bone/dcmeet2/MVC-887X.JPG
Old Apr 26, 2001 | 07:55 PM
footemps's Avatar
OSCAI? what's that? i know CAI is Cold Air Intake but what's the OS?
Old Apr 26, 2001 | 07:57 PM
kinda like a home made CAI, and very cheap.. can get ur materials at Homedepot for 50 bucks or less easily. read the stickies
Old Apr 26, 2001 | 08:23 PM
footemps's Avatar
i did read em... i just wanted to clarify... i didn't get some of the sticky posts
maxinout93
Oct 31, 2015 02:04 AM
magiconthetire
Oct 26, 2015 09:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
