Dashboard panel disassembly tips?
Old Dec 7, 2004 | 11:54 AM
spirilis's Avatar
Hi-
Anyone have any tidbits, pictures or guides on removing the dashboard trim? I need to remove the lower (driver-side) dashboard trim panel (including the fusebox cover, under the steering column, etc.)
Last time I took a look, there were 2 screws I removed from the bottom, but didn't have enough time to figure out where the rest were...
Thanks!
Old Dec 7, 2004 | 12:55 PM
spirilis's Avatar
hmm, found this while searching: http://forums.maxima.org/showthread....strument+panel
5. Remove the driver’s side kick-panel (under the steering wheel). It is attached with 2 screws and 2 small nut bolts
I must've missed those 2 small nut bolts.
Old Dec 7, 2004 | 01:04 PM
goldmaxNYC's Avatar
the rest just pull , a little bit of force and it comes right off. it snaps in 2 or 3 places on the top part.
Old Dec 7, 2004 | 01:21 PM
spirilis's Avatar
Are these small bolts at the top or the bottom?
I know where the 2 screws are, just not sure about the bolts.
Old Dec 7, 2004 | 03:41 PM
nyautostyle's Avatar
there 2 screws, one on the left and one on the right. should snap right out when u pull toward you. remember the taps are at the top of the piece, where the screws are on the bottom of the panel.
Old Dec 7, 2004 | 03:56 PM
Epacy's Avatar
Unsuccesful STL Coordinator
This is a dealer only project.
Old Dec 10, 2004 | 04:57 PM
spirilis's Avatar
har.
Thanks for the insight--I went ahead and completed the project I was doing, tucking my OBD-II scantool wires inside the dashboard with a single serial port exposed through a trim piece on the left side. Works properly this time (last time I rigged it without removing the dash panel piece, it was a clusterf*** and it didn't even work, lol... now it's mounted a little more cleanly.)
Old Dec 10, 2004 | 05:25 PM
Epacy's Avatar
Got pics?
Old Dec 10, 2004 | 06:08 PM
spirilis's Avatar
No.
Old Dec 10, 2004 | 06:23 PM
spirilis's Avatar
Just kidding.
Here's some pics:
Old Dec 10, 2004 | 06:24 PM
spirilis's Avatar
Oh, I'm well aware that I accidentally over-cut the trim piece with my dremel, hence the little black hole above the port.
My fault, I was holding the piece in my hand and the dremel in my other hand. Since then, I've purchased a Dremel Drill Press, and two of those trim pieces from DAVEB. I'd like to redo that trim piece correctly sometime when I get bored, so it doesn't look so ghetto.
Old Dec 11, 2004 | 04:16 AM
spirilis's Avatar
lol, ironically, while driving around last night I got the P0430 code pop up again. Promptly turned on the Palm and cleared that sucker
gavin68
Sep 18, 2021 12:36 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
95naSTA
Sep 21, 2015 06:50 PM
GregL65
Sep 5, 2015 09:37 PM
